-   Nokia Hardware & Hardware Repair (http://forum.gsmhosting.com/vbb/f148/)
-   -   asha 311 auto off with sim need help (http://forum.gsmhosting.com/vbb/f148/asha-311-auto-off-sim-need-help-1662192/)
ashaka 05-22-2013 20:08
i have this phone with sim it switch off i have flash with lasest flash file problem the same any solution from members will be very appreciated
thanks.
jins jisha 08-21-2013 06:48
It should be hardware fault. Try to call sos without sim,if it switches off then change its PA.
gobinda 08-23-2013 10:31
nokia 311
hi gays last month same problem faceing and I replace rf power converter ic its work fine . this not software problem
rajeshlehal 09-01-2013 11:00
Can you share pictures, where is rf converter ic located in pcb ? Thanks in advance.........
smt_mamun 09-05-2013 10:39
without sim call 122 set ok problem network ic. but set of reshoeld CPU.
problem solve 1000% tested my me
ksprajapati 09-07-2013 08:45
wher power converter ic
mobile_sujan01 09-08-2013 19:37
bro but wen a change pa its same..prob..
salimmalikgolde 09-08-2013 19:55
remove the ringer and try
celldial 09-20-2013 14:39
asha 311
GSM_LORD 09-28-2013 15:27
try to run self test and see whats failed (using phoenix is preferred at local mode)
Jehrom 12-07-2013 04:14
check BSI line before changing PA problem will be solved 100% tested by me
anbuchelvansci 12-14-2013 14:23
Guys please cheak whether the phone is completely turned off or just display goes to off state , when I call 112 my display goes to off state , when I press call cancel button display come back to normal state.
Sent from my iPad using Tapatalk
khagen 01-05-2014 05:40
sir what should be change pf or rf......................plz provide us the pcb layout.....
Raj mobe care 01-05-2014 22:40
I flash in nokia care my phone working fine
john china 01-08-2014 04:09
its 100% pa faulty change it it will work
Page generated in 0.26242 seconds with 5 queries
