Old 08-25-2009, 09:13   #1 (permalink)
Member: 458909
Thanks Meter: 33
E71 charging problem
Hi, i received a Nokia E71. When charger pluged in, it shows charging, but the battery loses power. Any ideas? Will write PM help?
The Following 2 Users Say Thank You to Wynsak For This Useful Post:
Old 08-26-2009, 13:44   #2 (permalink)
Member: 458909
Thanks Meter: 33
Helooooo. I need advise on this problem. PLEASE HELP. Any ideas welcome.
The Following User Says Thank You to Wynsak For This Useful Post:
Old 08-26-2009, 17:11   #3 (permalink)
kapilgupta's Avatar
Member: 681945
Thanks Meter: 422
dear rehot its tahvo/betty ic, problem will solve 100%
The Following User Says Thank You to kapilgupta For This Useful Post:
Old 08-27-2009, 14:38   #4 (permalink)
Member: 458909
Thanks Meter: 33
Which shield do i remove for Betty ic?
Old 08-28-2009, 15:08   #5 (permalink)
kapilgupta's Avatar
Member: 681945
Thanks Meter: 422
[IMG][/IMG]
The Following 2 Users Say Thank You to kapilgupta For This Useful Post:
Old 08-28-2009, 15:11   #6 (permalink)
shakkeermp's Avatar
Member: 871211
Sonork: 808888
Thanks Meter: 37
Bro u must change avilma
The Following 2 Users Say Thank You to shakkeermp For This Useful Post:
Old 09-07-2009, 09:19   #7 (permalink)
Member: 458909
Thanks Meter: 33
Hi, which one should i go for, betty or avilma, or should i flip a coin?
Old 01-25-2010, 19:56   #8 (permalink)
Member: 103466
Thanks Meter: 2
Nokia e71 charging problem
plz help me i have a e71 when i charg it its not charging and i m alredy chek supplyes suplyes was ok but when i put charger its not charging
The Following 2 Users Say Thank You to GULJAAN For This Useful Post:
Old 03-08-2010, 17:22   #9 (permalink)
Crazy Poster
Member: 1249417
Thanks Meter: 4
please help me for e71 not charging i also change bt ic but same problem please help me thx
Old 03-08-2010, 17:38   #10 (permalink)
Member: 100241
Thanks Meter: 20
e 71 charge problem
try to change good ic betty your problem it solved
The Following 2 Users Say Thank You to charbel For This Useful Post:
Old 03-11-2010, 07:55   #11 (permalink)
Member: 1163944
Thanks Meter: 4
none of them jus change its charge ic coz if u play with tavho it will switch off
The Following User Says Thank You to wally.com For This Useful Post:
Old 03-11-2010, 07:59   #12 (permalink)
Member: 1163944
Thanks Meter: 4
jus chage betty bro ur prob will be solved
Old 03-11-2010, 08:09   #13 (permalink)
Crazy Poster
Member: 334947
Thanks Meter: 6
yes i have solved this problem it is due to betty ic its 10000000000000000000000000000000000000% sure
The Following User Says Thank You to binay For This Useful Post:
Old 03-11-2010, 08:22   #14 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.replace this betty ic.
The Following 3 Users Say Thank You to mahbubalfa For This Useful Post:
Old 08-11-2010, 22:25   #15 (permalink)
Member: 192672
Thanks Meter: 9
just remove one resisitor under the bettry connector's + line and direct it problrm solved.
The Following User Says Thank You to acacsexy For This Useful Post:
E71 not charging problem Afzal Chiri Nokia Hardware & Hardware Repair 7 09-15-2010 23:17
E71 CHARGING PROBLEM (no reaction) d'odders Nokia Hardware & Hardware Repair 3 07-07-2010 09:08
Need E71 Charging Ways Sydney_Unlocker Nokia Hardware & Hardware Repair 1 12-17-2009 11:39
E71 charging problem szozda2 Nokia Hardware & Hardware Repair 1 10-17-2009 14:02
E71 battery problem CrKdz13 SIEM Service Tools 5 02-06-2008 17:33
Page generated in 0.23965 seconds with 10 queries
