10-02-2007, 17:09 | #1 (permalink) |
Insane Poster Join Date: Jul 2006
Member: 321195 Status: Offline Thanks Meter: 5 | automatic file select ufs3 suite i m new in mobile repairng i cant select flash file plz if any ufs3 wich can select fash file automatic please poste here. plz plz plz.............. |
10-02-2007, 17:53 | #4 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Comilla Age: 42
Member: 304260 Status: Offline Sonork: 100.1593127 Thanks Meter: 355 | 1. select MCU+PPM+CNT file 2. Click Creat int button. then next time file auto select. thanks |
The Following User Says Thank You to .:Towhid:. For This Useful Post: |
10-03-2007, 08:58 | #7 (permalink) |
Crazy Poster Join Date: Jun 2007
Member: 536101 Status: Offline Thanks Meter: 3 | ini file generator hello brother pls use this tool.first you are select your mobile model number.then you will select your mobile varient number ex ( 056124 ).remove set battery you will see the varient and imei number.after select the varient give the command run ufs.this software run the ufs and it will generate your sets pm,ppm,cnt filles. |
10-03-2007, 18:15 | #8 (permalink) |
Junior Member Join Date: Sep 2007
Member: 599256 Status: Offline Thanks Meter: 0 | i m uploading some ini files simply copy all these files inn ur c:/windows/programefiles/nokia/product/phonics. all will be done . enjoy post result if any problem contact me 0321-6569344. |
10-04-2007, 00:58 | #9 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | hi, at first select mcu ppm cnt pm file then right side dawon spaces you get creat ini file click that one your work is ok for only that model only but this is not for your solution becoses all same model nt a same vertion......so try to leran about mobile softwear.....good luck.... |
10-15-2010, 11:05 | #14 (permalink) |
Junior Member Join Date: Aug 2010
Member: 1381346 Status: Offline Thanks Meter: 0 | How can flashing mobiles with UFS-3 Tornodo Dear all i am new user for Mobile Softwares. how can flashing mobiles via UFS-3 Tornodo. please tell me step by step please help me. i am facing many more problems with UFS-3 like no network signals, Ini normal mode failure" please help me thanque to all. ramesh [email protected] |
Automatically Detect Nokia flash File HWK latest Suite is Not working | mohit_kripalu01 | HWK | 9 | 05-06-2015 07:29 |
Need Nokia Automatic UFS FLASH FILE selection software... | amit123 | Nokia Hardware & Hardware Repair | 8 | 10-20-2009 10:51 |
Direct File Selection For Ufs3 Users | shivaprasadm | UFS2 + UFS3-Tornadoflasher | 2 | 05-23-2007 21:56 |
