Old 04-18-2004, 04:15   #1 (permalink)
Nabil3H's Avatar
Member: 17675
Thanks Meter: 18
Lightbulb B200 problem
Can we remove B200 from nokia 3310 and is still working?
i try this method and the phone is still runing of course slow ringtone but it work fine and able to flash and power on
Why if phone is dead we replace it to power on again?
what is the function of B200 " in case the phone is dead " ?
Thanks
Old 04-19-2004, 18:50   #2 (permalink)
Member: 39601
Thanks Meter: 13
B200 is the " sleep mode clocker " of the phone it works at the time of no use of the phone for data refreshment rithm but at lower speed ( for energy saving ), If U read any full service manuall ( specially the baseband section ) U'll find it well explained , also U have to do further searshing on the forum if U still need additional infos.
Regards
Old 04-19-2004, 20:32   #3 (permalink)
Member: 1060
Thanks Meter: 10
It is clock for your CCONT
once you put battery, then it use 2 gates of CCONT to work for 32.768khz !
when phone into "sleep" mode, then 26Mhz also sleep ! phone need 32.768K to keep a clock to work for wake up MCU !
see, it is NEEDED !
regards
Willy
Old 04-20-2004, 05:27   #4 (permalink)
Nabil3H's Avatar
Member: 17675
Thanks Meter: 18
Red face Thanks
Thanks for information Medz and Willy
that mean the MCU wake up "work" from B200
in case of phone off what is the function of it to power the phone or not
in case of B200 existing the phone power on
in case of B200 remove the phone power on
what is the difference?
thanks for help
Old 04-20-2004, 05:43   #5 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
Try to use 3310 without 32kHz quartz - you will get no only slow tones, but also jumping network, and also other (de)effects ...
Old 04-20-2004, 05:51   #6 (permalink)
Nabil3H's Avatar
Member: 17675
Thanks Meter: 18
Red face
I know slow ringtons and network problem is exist by remove B200
but it does not effect the power on behavior the phone is still power on
but i ask in many service manual and also in forum if the phone is not power on it is one of the problem "B200"
Why?
Thanks for reply
acount id problem.help uregent plz [SOLVED] dani2080 PolarBox 3 2 03-29-2010 12:46
Samsung B200 Buzzer problem, please help! SSTHO Samsung Hardware Repair 3 12-22-2009 11:30
B200 flashing Problem luqmaan751 UST Pro II 0 06-18-2009 09:16
B200 big problem ehsas_ghum UST Pro II 0 01-11-2009 11:32
b200 unlock problem willy one UST Pro II 0 12-07-2008 13:15
Page generated in 0.26713 seconds with 10 queries
