08-21-2010, 07:41 | #1 (permalink) |
No Life Poster Join Date: Dec 2009
Member: 1191923 Status: Offline Sonork: sohana Thanks Meter: 170 | Baca <<BB5 Easy Tool by DSSv03 new update>> BB5 EasyTool v0.3 aka DSS Supported interface: USB, COMport, UFS How to Read an ASK files from BB5 phones: - Switch ON the phone - Install the phone using Supported interface. - Open DSS.exe - Select phone 'connection' then Click 'Connect' - Click 'Read ASK' How to Write RPL files to BB5 phones: - Switch ON the phone - Install the phone using Supported interface. - Open DSS.exe - Select phone 'connection' then Click 'Connect' - Click 'Write RPL' - Note: This function will write only SIMLOCK DATA to the phone, for imei repair you need flashers! How to use DSS as easyUID: - Copy DSS.exe to UID directory - Make proper testpoint to the phones - Switch ON the phone(with CORRECT testpoint connected between phone and UID BOX) - Install the phone using Supported interface. - Open DSS.exe - Select phone 'connection' then Click 'Connect' - For better result, you should set then phone mode to 'TEST MODE' before unlock process - You will see 'easyUID' page. - Click 'Hook' - Select Phone model listed on bb5_unlock.exe(UID SW) - Click 'Init' on bb5_unlock.exe - Set 'options' to use #pw+...+?# if required. - Click 'SP unlock' ('delay' before unlock process implemented) - Wait for bb5_unlock.exe to work, DSS.exe will automaticaly detect the code calculated by bb5_unlock.exe and write it to the phone. Download link is here:http://www.gsmsimlocking.com/BB5/ind...asy+UID+by+DSS |
The Following User Says Thank You to mahedi_de For This Useful Post: |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
