11-17-2007, 12:24 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: akola
Member: 336192 Status: Offline Thanks Meter: 53 | 6085 shows following massage RAPx ID : 000000010000022600010006010C192101001101 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 2A300219CC540058320B977A0512696EB3F42541 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 191EC665DFAAF68F CMT 1st Boot OK CMT 2nd Bt: RAP3Gv3_2nd.fg, Ver: 1.20.2 CMT 2nd Boot OK CMT ALGO : RAP3Gv3_algo_fps8.fg, Ver: 1.12.5 00000000: 02 00 00 00 00 D1 72 ......r ERR: CMT Alg Boot Alg Bodr: Process Failed, Repowering Mobile when connected to ufs 6085 shows following massage any solution............ |
11-17-2007, 14:55 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | brth try to flash it with jaf or mt if same then check in hardware problem in cpu or flash ic............good luck digitized |
12-17-2007, 11:36 | #3 (permalink) |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | First of all tell me which version of UFS Suite you are using. You must use HWK to successfully flash BB5 sets. If you are already using these, please check Dual Line option in UFS-HWK 2.0.6 and try. If it does not work, wash the board put some paste on UPP and Flash IC and apply adequate heat. Be carefull. Try and post result. Good Luck Bro! |
6233 camera problem...hang(but not showing error massage | broken_rules | Nokia Hardware & Hardware Repair | 19 | 09-17-2011 02:20 |
Dead nokia 3660 showing following message.. | amit123 | Nokia Hardware & Hardware Repair | 2 | 05-12-2009 07:39 |
Dead Nokia 3310 Set Showing Following Informations... | amit123 | Nokia Hardware & Hardware Repair | 0 | 03-31-2009 10:55 |
V3i Repair PDS show this massage. | maheshsaiganesh | Smart-Clip | 2 | 06-23-2007 12:11 |
show this massage Error # 10054 probleme solved | abhishek aga | HWK | 4 | 06-05-2006 10:52 |
