12-21-2010, 06:39 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | The Best Solution For Nokia N85 N86 Charging
Here i am Posting the solotion checked by us,almost not work for us |
The Following 27 Users Say Thank You to ..::AppleLinks::.. For This Useful Post: |
12-21-2010, 06:41 | #2 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | SOME others are HERE................... |
The Following 16 Users Say Thank You to ..::AppleLinks::.. For This Useful Post: |
12-21-2010, 07:48 | #3 (permalink) |
Insane Poster Join Date: Nov 2006
Member: 393989 Status: Offline Thanks Meter: 11 | BIG thanks Brother.....But we have some problem.Please Rename your pics with perfect name and problem, coz when some body searching any problem in google then we will can't find your pics.your pics are renamed with alphabetcal or nomaricaly. any way thanks again for good posting. keep it up. |
The Following User Says Thank You to mr_suspend For This Useful Post: |
12-21-2010, 10:40 | #4 (permalink) | |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Quote:
The Following User Says Thank You to ..::AppleLinks::.. For This Useful Post: |
12-22-2010, 07:35 | #5 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | some other guys should also post their complete and an uncompleted stories |
The Following 3 Users Say Thank You to ..::AppleLinks::.. For This Useful Post: |
12-23-2010, 08:17 | #7 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Confirm ok Observation:Today i receive a N85 with destroyed charging base and its points, i only connect the one ground and the positive line. Result:Only USB list and no charging on screen. We did make all lines from charging base to the desire pints.phone charging well and also USB connectivity. we will pref-are the following solution http://forum.gsmhosting.com/vbb/atta...2&d=1292910065 |
12-23-2010, 08:21 | #8 (permalink) |
Freak Poster Join Date: Apr 2009 Location: pakistan Age: 39
Member: 1019981 Status: Offline Sonork: [email protected] Thanks Meter: 98 | thanks brother nicee work |
12-23-2010, 12:52 | #9 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | some info about wrong solotion Here i am Posting a solution exist on net/forum for Nokia N86 Charging Ways, which is absolutely wrong,users are mistakes with this solution,here i am point that solution,plz check and confirm,and report here...... The Best Charging ways Tested 100% Nokia N86 |
The Following 13 Users Say Thank You to ..::AppleLinks::.. For This Useful Post: |
12-27-2010, 05:51 | #10 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | I get a N86 which Charing Base all points are Dem-aged i connect all points. But No USB Connectivity and also not taking Charge. i found the ic N3303 you can check in above picture is missing,i did not find any help about this ic in schmatic. So wanna need and info-help or jumper about N3303,any one have???? |
12-29-2010, 18:29 | #13 (permalink) |
Insane Poster Join Date: Jul 2006 Location: uae Age: 46
Member: 321538 Status: Offline Thanks Meter: 10 | n3303 it is just a diode like zener diode as in nokia 1110. if it is shorted out all the positive charge voltage goes to ground. it this one is removed the charging voltage goes to the other related parts of circuit. thats all |
The Following User Says Thank You to yasindae For This Useful Post: |
12-30-2010, 06:25 | #14 (permalink) | |
Not taking charge,(the points was destroyed,i make.) when i remove the N3303,the symbol was gone and no response of charge. i checked the positive point well going to other parts,this was due to charging base destroyed. | |
