Old 03-11-2004, 13:43   #1 (permalink)
Member: 52884
Thanks Meter: 13
Cool bga ic
hi i have check mobile-tech on how to replace BGA ICS,but there is one problem that is not clear to me .when u remove BGA ICS there is always some BALLS+FLUX on d PCB.do we use hotair to remove the ball/there is a liquid that is use to dissolve d balls b/4 replacing d ic.
Old 03-11-2004, 20:34   #2 (permalink)
Member: 39601
Thanks Meter: 13
@buschell
This link contains a thread here from yesterday , read it and go to the links with the photos , they give in detail how to do it , also how to clean it with the wick sheild
http://forum.gsmhosting.com/vbb/showthread.php?t=131074
GoodLuck
Old 03-21-2004, 17:52   #3 (permalink)
Member: 28378
Thanks Meter: 3
Just put some flux solution, then you can remove the balls using a soldering iron with a good tip; but you have to clean after with a desoldering wire.
I need BGA IC ball making MACHINE DrMobile Hardware Repair Item Wanted 5 09-08-2005 21:18
repair damage soldering contact point for the BGA IC video wingsold Hardware Repair by brands 3 11-08-2002 08:20
can esd really damage bga ic???? eureka8888 Hardware Repair by brands 0 05-05-2002 21:48
8210 glue under ccont bga ic digipulse Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 03-02-2002 21:21
Cobba BgA ic problem rhd Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-26-2001 13:05
Page generated in 0.14102 seconds with 10 queries
