View Poll Results: what about ..............? | |||
GOOD | 2 | 66.67% | |
NOT GOOD | 1 | 33.33% | |
Voters: 3. You may not vote on this poll |
03-01-2003, 04:28 | #1 (permalink) |
Freak Poster Join Date: May 2002 Location: egypt Age: 46
Member: 11466 Status: Offline Thanks Meter: 0 | Bridge 4 test PA(3310) to test yr PA if u r not sure where is the broplem for 3310 as example u have four pin on left and four on right make a connection by small wire from pin no. 1 from right and pin no.1 from left and pin no. 4 from right u will get a network if yr broplem in PA (just for TEST) u can`t make a call by that in some time call and anouther time no tested 100% |
03-08-2003, 17:16 | #2 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: Bridge 4 test PA(3310) Quote:
I am sorry ! i closed this thread ! why you keep on do some thing "useless" poll in your post ? do you think, that wire bridge will help to test phone RF problem ? what mean " u will get a network "? in some case, you are far to network , then you will think, that will get net work to answer you ? if PA is no good, or you think PA is no good, then you can try to put that fault PA to working phone to test on it ! more easy way, use micro voltage meter or RF blanking LED to test PA "input" before you remove PA ! please do not do "poll" for nothing Willy | |
myc-4 test point | REMO | ARM9 BASED M62 / M62+ | 9 | 03-13-2005 10:59 |
1.3f 4 test | 4R | UFS2 + UFS3-Tornadoflasher | 16 | 12-23-2004 20:19 |
Bridge 4 test PA (8210) | amir-cairo | Nokia Hardware & Hardware Repair | 0 | 03-01-2003 04:43 |
