02-25-2005, 16:24 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: UKRAINE Age: 46
Member: 22400 Status: Offline Thanks Meter: 44 | BT IN 6600 Problem Flashing Fl0: 0x00000000-0x007FFFFF,002088C0,St M28W640 Fl1: 0x02000000-0x027FFFFF,002088C0,St M28W640 Fl2: 0x04000000-0x047FFFFF,002088C0,St M28W640 Fl3: 0x06000000-0x067FFFFF,002088C0,St M28W640 Algorithm: w3_st_i.fia, w3_cbusb.fia Algorithm Ok, MSID: 842072A57F56FE5C5B875802E7 Decoded MSID: 3E4EBAF7-00599616-A8000000 Encoded FAID: 24ECDC16-366393C1-EF0E4C7F Cbus Boot Error: 9 Error Data1: 00000000: 00 96 84 20 72 A5 7F 56 FE 5C 5B 87 58 02 E7 F2 ... r.V.\[.X... 00000010: 88 00 00 00 00 04 20 00 C0 88 00 00 00 00 06 20 ...... ........ 00000020: 00 C0 88 00 00 00 00 FF FF FF FF FF FF FF FF FF ................ 00000030: FF FF FF FF FF FF FF 5B 00 00 00 00 00 00 00 00 .......[........ Error Data2: 00000000: A3 72 72 C0 88 00 00 00 00 02 20 00 C0 88 00 00 .rr....... ..... 00000010: 00 00 04 20 00 C0 88 00 00 00 00 06 20 00 C0 88 ... ........ ... 00000020: 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF ................ 00000030: FF FF FF FF 5B C3 72 00 00 00 00 00 00 00 00 00 ....[.r......... Before taking screenshot, expand this window ! Process Failed, Repowering Mobile IF im no select option ----flashing BT--- phone flash ok! I change CPU FLASH IC UEM in Compaund - no change who heve solution??? thanx!! |
02-25-2005, 16:30 | #2 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Cyprus Age: 42
Member: 15149 Status: Offline Thanks Meter: 61 | check cable if you have other one maybe it help i have the same problem or try to erase and then write fullerase6600 in mcu and ppm and then write good mcu and ppm files, pm. |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
BT in the 6600 | nyo.pa | n-Box | 5 | 12-18-2005 16:47 |
