12-24-2003, 11:11 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Age: 36
Member: 47281 Status: Offline Thanks Meter: 17 | Building Cables |
12-24-2003, 20:28 | #3 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | The 1N4148 diodes are verey verey common ,they are the basic universal levels of diods. U'll find them in any electronic PCB,toy, calculator, clock , ect. The IC 74Hc14 is a hex (6) "schmidt " inverters , U can replace it with the 74HC04 ( the same ) but U'll lose the (schmidt) facility wich is importatnt for the stabelity of the pulse streem interfaceing. |
12-27-2003, 14:02 | #5 (permalink) |
Member: 47281 Status: Offline Thanks Meter: 17 | building cables It's me again, netdragon!! well thankyou 4 replying. i'll try 2 find the diodes in calculators or electronic PCB'S. well, as i mentioned i built the cable without the diodes. when i connected it with my 7110 i tried 2 read the phone with Rolis, it read and mentioned something like : MCU chk less and asked me 2 save the file it was only 4kb. i emulated communication with knok but said can't find ppm block and try overrule flash file. well you might say that why didn't i read the phone with knok?? bcoz when it's time 2 switch on the phone knok says cannot prepare phone on the other side, with rolis when it read a part of it @ the status it's written NSE-5 phone not accept flash read command AFTER HAVING SAVED THE 4KB flash file!! now my phone is saying : contact service. What do i do now?? do reply. by the way is 1N4148 included in data cables? & another question: will data cable flash if i uses a converter 25pin>9pin?? plz do reply i'm very desperate!! |
12-27-2003, 17:52 | #6 (permalink) |
Insane Poster Join Date: Oct 2003 Location: Algiers, ALGERIA Age: 50
Member: 42161 Status: Offline Thanks Meter: 1 | If you just want to unlock it, it's easier to use an M-BUS cable, because it uses only two wires, and the software (i use the old nokia tool buid 34) works fine with earlier models !! it can also display security code for new models, and can perform full factory reset for some phones wich even don't accept the displayed security code !! |
01-01-2004, 23:46 | #7 (permalink) |
Freak Poster Join Date: Sep 2003 Location: hell
Member: 39245 Status: Offline Thanks Meter: 43 | I've ever build that flasher and I complete it successfully. IN4148 diode was the very common diode. So just build it as in the schematic!!!!!!! Don't use the 25 to 9 pin converter cause flasher uses 25 pin (LPT port) that in 9pin (Com / RS232) has no that kind of pin in it. IF it is still no success.... buy it. It was very cheap. BR, Djo |
02-22-2004, 04:20 | #8 (permalink) | |
Freak Poster Join Date: Feb 2004 Location: mauritius Age: 38
Member: 54469 Status: Offline Thanks Meter: 1 | Quote:
please help me build a flasher... | |
02-28-2004, 13:06 | #9 (permalink) |
Member: 47281 Status: Offline Thanks Meter: 17 | How to assemble cable? hi, I've got all the components required. i breadborded the components but flasher cable is not working... i need step-by-step detail on building the cable with graphics if possible. please help me. i badly need my phone. regards, |N|3t Dragon |
02-29-2004, 04:42 | #10 (permalink) |
Member: 54469 Status: Offline Thanks Meter: 1 | hi net dreagon?? u are from mauritius?? me too please help me build my flasher cable as me too i badly need my phone, we could join hands for example... |
02-29-2004, 13:40 | #11 (permalink) |
Member: 47281 Status: Offline Thanks Meter: 17 | so, u wanna build the cable? assalamualaikum, ki p dir la?? first u need to buy the required components: - IC 74HC14 - CAPACITOR ELECTROLYTIC 100nf (OR 0.1uf) - RESISTOR 4700 ohms - 2 DIODES 1N4148 - A CONNECTOR PROM PARALLEL PORT(PRINTER PORT) then u need to mount it accrding to the electronic scheme. well, where do u live exactly? u can sms me on +2304948192. |
02-29-2004, 22:41 | #12 (permalink) |
Freak Poster Join Date: May 2002 Location: Portugal Age: 42
Member: 12207 Status: Offline Thanks Meter: 2 | Hi! this is an easy one to build... I don't have pictures of it! U need only to worry, about capacitor polarity, the way you put the diodes in the cirtuit! in the capacitor, the negative pin (-) will go to ground. For the diodes, that | representes the black circle in the diode itself! i assume you know the chip pinout... oh, and another thing... you dont need to put all those signals in the mobile! for example, 3310 don't have Btemp. Hope it helps... Regards... XARiUS |
03-01-2004, 02:35 | #13 (permalink) |
Member: 54469 Status: Offline Thanks Meter: 1 | walékoum salam, korrec toi?? mari chance pou zoine ar toi ici!! moi, curepipe toi?? thanks a lot for helping me, i will start assembling it as from now |
I have build cable flash for sciphone i68+ | dariodediablo | Infinity-Box | 3 | 09-19-2009 12:10 |
how to build cable to unlock my100x, new board without tp | GOODNESS | SAGEM JTAG UNLOCKER | 2 | 06-08-2008 11:13 |
Help me pinout v10 build cable not ok | halongmobile | Infinity-Box | 6 | 04-17-2006 22:12 |
How to build cable for NME-3 | Mobilmicke | UFS2 + UFS3-Tornadoflasher | 0 | 07-19-2005 13:05 |
sharp gx10 result after build cable | Chawkiz_gsm | Sharp | 6 | 04-18-2003 00:50 |
