Old 11-05-2012, 12:40   #1 (permalink)
Member: 1691448
Sonork: 1619100
Thanks Meter: 40
c1 01 help need urjnt
set is ok but if i in memory card then set is white screen only...without memory set ok.i flash it but not solve any solution pls help me
The Following User Says Thank You to gsm_sujan For This Useful Post:
Old 11-05-2012, 12:46   #2 (permalink)
.::zaif::.'s Avatar
Member: 1754969
Sonork: 100.1616247
Thanks Meter: 27
cheng mmc ic then chk
The Following User Says Thank You to .::zaif::. For This Useful Post:
Old 11-05-2012, 15:24   #3 (permalink)
zoiya's Avatar
Member: 740220
Sonork: 100.1654997
Thanks Meter: 253
zaif is right i solve this problem many time by changing mmc ic
The Following User Says Thank You to zoiya For This Useful Post:
Old 11-05-2012, 18:54   #4 (permalink)
Member: 1766383
Thanks Meter: 4
1000000000000000000%%%%%%%%%%% change mmc this probilem solve i do it many time its not s-w problime.
Old 11-05-2012, 20:55   #5 (permalink)
Member: 1071128
Thanks Meter: 33
change mmc ic or jumper it. :P problem solved thanks
Old 11-06-2012, 18:28   #6 (permalink)
Member: 1691448
Sonork: 1619100
Thanks Meter: 40
thankz all???????????????
Page generated in 0.13227 seconds with 9 queries
