Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 04-21-2012, 07:29   #1 (permalink)
kathirmobiles's Avatar
Member: 1591177
c2-01 flash ok factory set failed help me
log hare
Number of Image Files: 3
Processing Image File :
rm721__11.20.mcusw
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 3250000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 19500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 158
Entry Point: 0x0259
Page Format : -1
MAX PAGE : 0x00040000
rm721__11.20.ppm_dtm
CMT Type : BB5
Number of Blocks : 29
Entry Point: 0x011D
Page Format : -1
rm721__11.20_004.image_d_tmo_me_9h3p0
CMT Type : BB5
Number of Blocks : 68
Entry Point: 0x0154
Page Format : -1
AUTO SELECTED DEAD USB FLASHING...
If Flashing DOES NOT Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
BootRom Verified!
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00000001
ID DWORD 3 : 020C1921
ID DWORD 4 : 02044100
2 ROM_ID 15
Block Length : 5 (05)
ID DWORD 0 : 00001051
3 ROM_ID 15
ID DWORD 0 : 00001060
4 PUBLIC_ID 12
ID DWORD 0 : 27800010
ID DWORD 1 : EF005940
ID DWORD 2 : CE917DE3
ID DWORD 3 : 28004F69
ID DWORD 4 : 6EA2ED20
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 67E82268
CRC 1 : F29CEA60
START FLASHING
RawLoaderExtract: rm721__11.20.mcusw
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAP3Gv40_2 nd.fg
Secondary Loader Sent....
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : C1
SubBlocks : 06
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> not used
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0030 -> K5W1G13ACB
Revision ID : 0431
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data :
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Flash Descriptor
Device ID : 0030
Revision ID : 0000
Size : 08000000 (128 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAP3Gv40_X SR17_alg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
START READING RPL DATA
IMEI: 355940044778247
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\355940044778247\3559400447782 47_114751.rpl
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
8443ECD57D2EDADDAADBAD248F1B3B559E14D184
ImagePath: D:\Program Files\Nokia\Phoenix\Products\RM-721\
ImageFilename: rm721__11.20.mcusw
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 000A0000
Partition 2
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 02CC0000
Partition 3
Start Address : 077C0000
Partition 4
Start Address : 07B40000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 0002000A000002720000000000080000000102CC000004B000 000000000A00000001077C0000003800000000000B00000001 07B4000000180000C9
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0xE1 (225)
ERASE Blocks : 0x04 (4)
0 ERASE_AREA_BB5 0x12
Block Length : 0x4B (75)
Device Index : 0x00
0 : 00020000-000203FF
1 : 00060000-0009FFFF
2 : 000A0000-0025FFFF
3 : 003E0000-005DFFFF
4 : 005E0000-010DFFFF
5 : 01EC0000-01EDFFFF
6 : 027C0000-02CBFFFF
7 : 077C0000-07B3FFFF
8 : 010E0000-01EBFFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x02000000
Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000
2 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000
3 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 000000000000000B0000000000000002000000640000000200 000002000000010000000000000000
ERASE_REQUEST_BB5 : 5009120B00030000020000000203FF120B0003000006000000 09FFFF120B000300000A00000025FFFF120B000300003E0000 005DFFFF120B000300005E0000010DFFFF120B00030001EC00 0001EDFFFF120B000300027C000002CBFFFF120B000300077C 000007B3FFFF120B000300010E000001EBFFFF3D
FORMAT_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 00020000006400000002000000020000000100000000000000 003B
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 00020000006400000002000000020000000100000000000000 003B
Successfully erased..
Total blocks to write : 158
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
>> CMT Rootkey Hash CERT : MCUSW1
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : ISA+DYNSW
ImageFilename: rm721__11.20.ppm_dtm
StartErase_DCT5...
BlockLength : 0x0E (14)
ERASE Blocks : 0x01 (1)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01EE0000-027BFFFF
ERASE_REQUEST_BB5 : 5001120B00030001EE0000027BFFFF74
Total blocks to write : 29
ImageFilename: rm721__11.20_004.image_d_tmo_me_9h3p0
StartErase_DCT5...
BlockLength : 0x3F (63)
ERASE Blocks : 0x02 (2)
Device Index : 0x00
0 : 02CC0000-077BFFFF
Device Index : 0x00
ERASE_REQUEST_BB5 : 5001120B00030002CC0000077BFFFF90
Total blocks to write : 68
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000001
Additional Bad : 00000001
Correctable ECC : 00000000
FlashInfo.RestartMode : 2
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:01:42
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Elapsed Time: 5 Seconds...
Elapsed Time: 10 Seconds...
Elapsed Time: 15 Seconds...
Elapsed Time: 20 Seconds...
Elapsed Time: 25 Seconds...
Elapsed Time: 30 Seconds...
Elapsed Time: 35 Seconds...
Elapsed Time: 40 Seconds...
Elapsed Time: 45 Seconds...
Elapsed Time: 50 Seconds...
Elapsed Time: 55 Seconds...
Elapsed Time: 60 Seconds...
Elapsed Time: 65 Seconds...
Elapsed Time: 70 Seconds...
Elapsed Time: 75 Seconds...
Elapsed Time: 80 Seconds...
Elapsed Time: 85 Seconds...
Elapsed Time: 90 Seconds...
Elapsed Time: 95 Seconds...
Elapsed Time: 100 Seconds...
Elapsed Time: 105 Seconds...
Elapsed Time: 110 Seconds...
Elapsed Time: 115 Seconds...
Elapsed Time: 120 Seconds...
Elapsed Time: 125 Seconds...
Elapsed Time: 130 Seconds...
Elapsed Time: 135 Seconds...
Elapsed Time: 140 Seconds...
Elapsed Time: 145 Seconds...
Elapsed Time: 150 Seconds...
WARNING: Phone is not in the Required Mode...
Disconnect the Phone and Power it Up Manually.
Old 04-21-2012, 07:57   #2 (permalink)
anwar.welltech's Avatar
Member: 952533
Sonork: 1001607366
may be local mode problem, clean pcb then flsash again
Old 04-21-2012, 08:19   #3 (permalink)
Member: 1591177
all redy clean but still any other solution bro
Old 10-18-2012, 20:39   #4 (permalink)
Temporary banned !!
Member: 582600
just mx box bush check and go to service tap select all ok
Old 10-19-2012, 06:17   #5 (permalink)
Member: 1364048
tq tq tq tq tq bsssssssssssssssssssssss
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:04
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Page generated in 0.43799 seconds with 11 queries
