Old 05-14-2012, 08:36   #1 (permalink)
yogesha123's Avatar
Member: 905341
Thanks Meter: 64
c2-03 local mode
c2-03 localmode pleas help me
Old 05-15-2012, 08:45   #2 (permalink)
N.C.Erepola's Avatar
Member: 1615710
Sonork: 100.1647890
Thanks Meter: 200
Flash with higher version file.
Old 05-15-2012, 12:00   #3 (permalink)
kathirmobiles's Avatar
Member: 1591177
Thanks Meter: 85
bro flash same product code file post result
Old 06-25-2012, 11:46   #4 (permalink)
Member: 866650
Sonork: mdsalimkhan_05
Thanks Meter: 134
Yes
Today I face test mode c2-03
I flash fully with higher version
Old 10-25-2012, 17:32   #5 (permalink)
Marscel_Jr's Avatar
Member: 1121495
Thanks Meter: 28
after replace IC CPU pls solution.......
Connection status: UHCI:HUB:HUB::USB 1.10 (Full-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14119(16-06-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 205E4387
Device synchronized.
CPU: XGOLD 213
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.37
EBL version: Quantum_Bootloader_10.37_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI:
RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD__back.RPL)
Processing file: rm702__06.97.mcusw
Downloading item CODE:rm702__06.97.mcusw_ebl_psi.fls, num block: 4, size: 28 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.390 s
Erasing area 0x40040000-0x4005FFFE ...OK
Programming completed in 0.375 s
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.532 s
Erasing area 0x40280000-0x41D3FFFE ...OK
Programming completed in 35.296 s
Checksum verified (0xA701)
Processing file: rm702__06.97.ppm_x
Downloading item CUSTackage_x.ppm_ebl_psi.fls, num block: 1, size: 5.29 MB
Erasing area 0x41DC0000-0x4230A0BA ...OK
Programming completed in 7.078 s
Checksum verified (0x872D)
Processing file: rm702__06.97.image_x_059L5S7
Downloading item CUSTackage_x_059L5S7.image.fls, num block: 1, size: 12.38 MB
Erasing area 0x424C0000-0x43E1FFFE ...OK
Programming completed in 16.984 s
Checksum verified (0xE7B5)
Total time for flashing process(boot+erase+write) was 9 min 33.594 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia C2-03 USB Phonet, PORT_ID: 24C14632
Verifying communication to device OK.
Phone type: RM-702 (C2-03)
SW version: V 06.97 20-09-11 RM-702 (c) Nokia
Imei plain: 12345610654321-?
Product code: 059L128
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: 06150123008027, ver:
Imei plain is invalid !!!
SIMLOCK_DATA corrupted!
Market items is empty, please select the correct products path !
3390 v7.03 f_loader and partial flash needed Bads Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 03-17-2001 18:05
NetMonitor on Nokia 5110 & PC-Locals V1.3 SashaM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-31-2001 10:12
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
Page generated in 0.26103 seconds with 8 queries
