04-04-2013, 06:56 | #1 (permalink) |
Freak Poster Join Date: Jan 2011 Location: philippines
Member: 1501033 Status: Offline Thanks Meter: 35 | c3 dead need your help no water damage, not grounded,i change transistor the same. i try to flash with mx-key but can't read the phone. somebody help me to solved this thanks in advance |
04-04-2013, 20:17 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | which transistor bro ? try to clean d whole pcd then check . also reflow or reball juno (power ic) then check . |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
04-05-2013, 00:49 | #3 (permalink) |
Member: 1501033 Status: Offline Thanks Meter: 35 | thanks to your reply sir yes i notice that juno will gets hot when you put battery i change it to the new one but problem is the same. try it to reball it again but the same.. juno will not hot anymore... where i get the same juno of c3? |
The Following User Says Thank You to ren_mglab For This Useful Post: |
04-05-2013, 17:35 | #4 (permalink) |
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | reball properly , make sure all solder ball's are soldered well . did u check d unit with software after change juno ? try to replace new juno or from another set then check . post result |
04-06-2013, 07:57 | #6 (permalink) | |
Member: 1501033 Status: Offline Thanks Meter: 35 | Quote:
