Old 09-22-2008, 11:06   #1 (permalink)
Member: 554393
Thanks Meter: 7
NOT CHARGING 3500c
Not charging nokia 3500c pls reply fast
The Following 2 Users Say Thank You to Kishan247 For This Useful Post:
Old 09-26-2008, 20:11   #2 (permalink)
Member: 316047
Thanks Meter: 11
The Following User Says Thank You to king222 For This Useful Post:
Old 09-26-2008, 20:19   #3 (permalink)
Member: 572872
Thanks Meter: 21
Originally Posted by kishan247 View Post
not charging nokia 3500c pls reply fast
hi,
first change fuse ,it is in keypad lower side.
Then 4 pin ic .
If not solve then you have to change thavo ic.
Your problem will surely solved.
Good luck..
The Following User Says Thank You to pavankhatri4024 For This Useful Post:
Old 01-23-2009, 13:08   #4 (permalink)
Member: 369369
Thanks Meter: 15
were, and what is thavo ic please explain
The Following User Says Thank You to nicemanbilly For This Useful Post:
Old 05-01-2009, 21:26   #5 (permalink)
javish's Avatar
Member: 535130
Thanks Meter: 36
please read and learn nokia schematic
The Following User Says Thank You to javish For This Useful Post:
Charging not supported..... and.....Not charging 100% solution R@ZIB-BD Nokia Hardware & Hardware Repair 20 04-06-2010 08:57
3660 not charging help plz dj.comcell WD2 & APE (Symbian Phones) 0 03-29-2010 14:08
NOKIA Charging Not Supported & Not Charging NEW HARDWARE EXE dulal044 Nokia Hardware & Hardware Repair 2 05-16-2009 15:33
Hello anybody, my Nokia-3210 is not charging it is showing not charging varma raj Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 05-25-2003 11:27
Page generated in 0.16531 seconds with 9 queries
