11-06-2001, 10:08 | #1 (permalink) |
Freak Poster Join Date: Jul 2001 Location: internet
Member: 5234 Status: Offline Thanks Meter: 0 | Can COBBA IC be changed |
11-06-2001, 11:10 | #2 (permalink) |
No Life Poster Join Date: Oct 2001 Location: China
Member: 6986 Status: Offline Thanks Meter: 0 | Hi friend I ve been change COBBA IC before ,But Can not calculated the check sum .I think you must has the tool to make the file.set if you used Dejan 1.02 box .Change CoBBA is my problem now so if you have any solution please contact me .<br /> You just say used Wintestla to tested the phone ? So please to tell me which version you used now or dend to me if posissble ? <br /> B.R |
11-06-2001, 20:10 | #3 (permalink) |
Crazy Poster Join Date: Oct 2000 Location: Bla
Member: 2342 Status: Offline Thanks Meter: 0 | If you change the COBBA you get a bad checksum - and the phone locks all 4 locks... (sometimes you get Contact Service...) Sorry, but i donīt know a way to restore those datas... |
11-07-2001, 08:19 | #7 (permalink) |
Member: 5234 Status: Offline Thanks Meter: 0 | [quote]Originally posted by AboAli:<br /><strong>If u want to change the cobba IC uve to read the Flash of the Phone u changes th Cobba From, and write it to the Target Phone. BR.<br />AboAli.</strong><hr></blockquote> <br />Hi is this the correct procedure?<br />1.Read full back up of phone<br />2.Change COBBA IC<br />3.Write full back up back to the phone |
11-07-2001, 08:24 | #8 (permalink) |
No Life Poster Join Date: Apr 2000 Location: near you Age: 60
Member: 1196 Status: Offline Thanks Meter: 6 | I am working on 8210 ,,and with changing cobba ,,all locks was closed ,,and dejan soft can not recalculate checksums and ID ,,,phone reset it self,,,when I return back cobba (old original)and flash phone with dejan 1.04 to recalculate checksum ,,phone also have good checksum ,,I look with VIPER new soft ,,but phone reset itself about 30 sec ,,and I return full backup(original) ,,,previousle readed before experiment ,,and now phone working well 100% ,,,I can experiment because phone have damaged ccont chip ,,and ccont can be replaced with another [ 09 November 2001: Message edited by: misel ]</p> |
11-07-2001, 09:58 | #9 (permalink) |
Member: 5234 Status: Offline Thanks Meter: 0 | [quote]Originally posted by misel:<br /><strong>I am working on 8210 ,,and with changing cobba ,,all locks was closed ,,and dejan soft can not recalculate checksums and ID ,,,phone reset it self,,,when i return back cobba and flash phone with deja to recalculate checksum ,,phone also have good checksumm ,,I look with VIPER new soft ,,but phone reset itself about 30 sec ,,and I return full backup ,,,previousle readed before experiment ,,and now phone working well 100% ,,,I can experiment because phone have damaged ccont chip ,,and ccont can be replaced with another</strong><hr></blockquote> <br />so when you reflash the whole back up 20000-40000 back to the phone with the changed new COBBA IC, will the phone still work? |
11-07-2001, 11:06 | #10 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Some where around the world.
Member: 3845 Status: Offline Thanks Meter: 2 | HI,to all<br />This the solution.<br />If you want to change cobba ic you can do that.<br />You must change 1 pair of ic cobba ic and flash ic(of course use dead phone cobba and flash ic must in good condition).After change maybe have 4 lock close(not always have 4 lock).And you can unlock without problem.Test by me 100% working.<br /> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> |
11-07-2001, 11:18 | #11 (permalink) |
Member: 6986 Status: Offline Thanks Meter: 0 | Hi GsmSolution yes,you right but I has done the same you ,but when all lock was closed I can not unlock without problem like you .When I change 1 pair of ic cobba ic and flash ic, normaly it work OK <br /> Please tell me how did you unlocked it ? <br /> B.R |
11-07-2001, 11:33 | #12 (permalink) |
Member: 3845 Status: Offline Thanks Meter: 2 | [quote]Originally posted by Billgate:<br /><strong>Hi GsmSolution yes,you right but I has done the same you ,but when all lock was closed I can not unlock without problem like you .When I change 1 pair of ic cobba ic and flash ic, normaly it work OK <br /> Please tell me how did you unlocked it ? <br /> B.R</strong><hr></blockquote> HI,Billgate<br />I use normal flasher to unlock it.If cannot i use jic unloker it work. Many 3310 phone have 4 lock and can't unlock with normal flasher(dejan v1.0)when you unlock still have 4 lock close.When use jic unlocker to unlock it will ok.<br />But sometimes success to unlock without any problem.Sometime no network i up/down grade version also cannot.Maybe eeprom security problem. <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="tongue.gif" border="0"> <img src="mad.gif" border="0"> |
11-07-2001, 11:44 | #13 (permalink) |
Member: 3845 Status: Offline Thanks Meter: 2 | [quote]Originally posted by Billgate:<br /><strong>Hi GsmSolution yes,you right but I has done the same you ,but when all lock was closed I can not unlock without problem like you .When I change 1 pair of ic cobba ic and flash ic, normaly it work OK <br /> Please tell me how did you unlocked it ? <br /> B.R</strong><hr></blockquote> HI,Billgate<br />The second problem maybe is your cobba ic damage.You use hotair gun too hot or flow long time to cobba ic.It that right. <img src="tongue.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="mad.gif" border="0"> |
11-08-2001, 01:46 | #14 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, If you change the so called 'pair' just reset full factory with WinTesla. There is nothing special in JIC unlocker that you need to transfer phone indentity ! Normally after change phone will ask for security code - put 12345 and the phone will work. Best Regards |
11-12-2001, 15:48 | #15 (permalink) |
No Life Poster Join Date: Dec 2000 Location: Austria
Member: 2832 Status: Offline Thanks Meter: 0 | How can I read Cobba Chip?<br />Is it written from Address 00000000-00200000?<br />How can I write Cobba Chip? [quote]Originally posted by misel:<br /><strong>I am working on 8210 ,,and with changing cobba ,,all locks was closed ,,and dejan soft can not recalculate checksums and ID ,,,phone reset it self,,,when I return back cobba (old original)and flash phone with dejan 1.04 to recalculate checksum ,,phone also have good checksum ,,I look with VIPER new soft ,,but phone reset itself about 30 sec ,,and I return full backup(original) ,,,previousle readed before experiment ,,and now phone working well 100% ,,,I can experiment because phone have damaged ccont chip ,,and ccont can be replaced with another [ 09 November 2001: Message edited by: misel ]</strong><hr></blockquote> |
can L770 imei be changed free with ust | brandon | UST Pro II | 5 | 10-15-2009 18:49 |
Can S710a's language be changed to chinese? | sofakingcool420 | TOTAL MultiServer | 0 | 06-05-2005 20:12 |
Can the IMEI be changed on MOTO V300? | a010454 | Motorola P2k | 13 | 09-17-2004 14:46 |
can hardware settings be changed? | blueyesdude | Nokia Multimedia | 0 | 12-09-2003 18:26 |
Can T100 IMEI be changed FREE | gazt | VLSI, Conexant, Skyworks and Old Models | 0 | 10-24-2002 18:18 |
