01-15-2006, 16:58 | #1 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 210449 Status: Offline Thanks Meter: 2 | can i add a torch device to back side of a 6600?? hw r u all. well some where i seen that,one guy is using a tourch (some thing like nokia 1100) on his nokia 6600,on hte back side panel,on the top side(upper side of camera). what will be the compondent??? can any one tell me all about this???? hw can ve connect it on the handset?? thanks in advance u can catch me in [email protected] too thanking you all |
01-16-2006, 11:52 | #2 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | u can add one extra bright LED inside the casing (with a small hole for light to come thru), series resistor to create a current supply for the LED (chosen to meet type of LED u use), and a micro switch to turn "torch" on/off. hide all component inside phone housing, with hole for led and switch. connect to battery direct. thats all |
Can you add a new cables to the soft????? | aslam870 | PadFinder box | 2 | 07-28-2009 07:31 |
CAn you add new SIEMENS file to support for SL75, S68, EL71, M81, ME81 and other new? | wgmmmx | MT-BOX | 0 | 10-21-2007 16:45 |
Can you add update from cid51 to cid52 becouse I don't see on support | wgmmmx | MT-BOX | 3 | 05-17-2007 15:25 |
How to get datasheet of Nk 6600 display ic & SE K500 Charging ic | .::AD Com::. | Nokia Hardware & Hardware Repair | 0 | 05-04-2007 15:06 |
How can I add a input method to my z600??? | WY.Z600 | Sony Ericsson | 1 | 12-27-2004 15:42 |
