Old 08-11-2002, 23:17   #1 (permalink)
Member: 11485
6210 hanging and switch off
Hi!!!
I have a problem with this phone, after power on phone work perfect but if i press any key phone is resetting or hanging (only wenn i press key). What's a problem???
Sorry for my bad english and thanks for help.
Old 08-12-2002, 00:12   #2 (permalink)
Crazy Poster
Member: 14218
It is either...
1. Water damage,
2. The softwaare needs upgrading.
Open your phone and have a look for any blue marks on the PCB.... if there is any kind of water damage
or blue mould, you can try repiring it in a Ultra Sonic Bath (PCB Cleaner) if you know anyone with one.
If there is no damage there, try upgrading the softwar on it (latest version v5.56).
Or if you cant be arsed to mess around with it send it to me or take it to a local phone shop and ask them.
Regards,
Ed.
Old 08-12-2002, 00:52   #3 (permalink)
Member: 11485
Thanks for reply. My phone is not water damage and i test it with all soft for 6210 an 6250. This is hardware problem.
I forget yet add that this phone loss network.
Old 08-12-2002, 08:47   #4 (permalink)
F C
F C's Avatar
Member: 6486
Sonork: 100.79846
Thanks Meter: 350
buddy just change the rubber on/off rubbad pad--
tested 100% work--
regards
gohar
Old 08-12-2002, 10:44   #5 (permalink)
Crazy Poster
Member: 11983
Hi pdm64. I had the same problem with a 6210 some weeks ago. The problem was that the power button was constantly pressed and obstructed by the case, and when I touched any key phone restarted.
Take a look to see if it could be by that.
Regards.
Old 08-12-2002, 13:07   #6 (permalink)
Member: 11485
I change power switch and no results.
Old 08-12-2002, 13:22   #7 (permalink)
F C
F C's Avatar
Member: 6486
Sonork: 100.79846
Thanks Meter: 350
MAN ITS NOT THE POWER SWITCH-- JSUT THE RUBBER PAD WHICH TOUCHES THE ON/OFF SWITH- TRY TO CHANGE THAT OR IT SHOULD NOT TOUCH DIRECTLY TO THE SWITCH--
REGARDS
GOHAR
Old 08-12-2002, 13:50   #8 (permalink)
Member: 11485
Thanks for reply but this is not rubber. Phone is death now i can't power on and i can't flash it but wddog is working.
Old 08-12-2002, 20:49   #9 (permalink)
george gsm's Avatar
Member: 14200
Sonork: Sonork id
Thanks Meter: 117
hi pdm64,
i think ali mola and pk2gsm are right. if is not results u can try to resoldering flash, ccont, cobba in this order. try the computer conection after each step
geo
Old 08-12-2002, 21:09   #10 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
Thanks Meter: 69
ARC
I think what vlinkers said is solution for presseing any key and phone is off
the problem is Phone HANGING AND RESETING
I think u should try Rehot FLASH AND RAM or replace them
It works for me 100%
Old 08-12-2002, 21:17   #11 (permalink)
Member: 1060
Thanks Meter: 10
Re: ARC
ARC
You have good idea,, i agree with you !
Most is RAM have connect problem, so phone can not write or re-new data in RAM area , it become wrong data read/write in RAM, and make it hung !
i think, this phone was fall down ..
willy
Old 08-12-2002, 21:59   #12 (permalink)
Member: 11485
Thanks for all this is the flash ic but i don't have a hardware to repair it.
6555 hang then switch off jamohaki Nokia Hardware & Hardware Repair 1 03-08-2011 08:14
1208 hang after 10 second and switch off umesh garg Nokia Hardware & Hardware Repair 23 09-28-2009 20:01
nokia 2610 hang and switch off. barthosyn Nokia Hardware & Hardware Repair 7 06-05-2009 19:47
nokia 6600 hang and power-off after pincode off rovick Nokia Multimedia 3 08-04-2008 12:23
E700 Keypad Hang Then Switch Off jamohaki Samsung Hardware Repair 2 11-02-2007 06:02
Page generated in 0.20439 seconds with 9 queries
