Old 07-20-2004, 21:27   #1 (permalink)
mohd_anan's Avatar
Member: 56617
Thanks Meter: 4
Can u tell me which cable to use for flashing DCT3 Nokia 6250
Hello every one.
I'm sorry 4 the stuipd quest.
Can u tell me which cable to use for flashing DCT3 Nokia 6250 please ?Can u tell me which cable to use for flashing DCT3 Nokia 6250
It was dead now Gaves me Contact Service .
I have dejan ,Flasher and Griffin.
Please
Anan
Old 07-21-2004, 00:54   #2 (permalink)
Member: 16036
Thanks Meter: 5
maybe 5110 conector can help,with correct software
Old 07-21-2004, 05:52   #3 (permalink)
mohd_anan's Avatar
Member: 56617
Thanks Meter: 4
Thank u
I'll try and let u know
Old 07-21-2004, 06:56   #4 (permalink)
Alkapone's Avatar
Member: 19265
Thanks Meter: 92
5110, 6110, 7110, 6210 ...
Old 07-21-2004, 07:23   #5 (permalink)
mohd_anan's Avatar
Member: 56617
Thanks Meter: 4
Oh....
I tried 6210 but it is not working I'll try the others
Thnks alot
Old 07-21-2004, 07:50   #6 (permalink)
DMD
DMD's Avatar
Member: 12660
Thanks Meter: 7
@ mohd anan
I see your new are you trying to flash the phone using a data cable??
To flash Nokia Dct3 phones you need a Dejan dongle or similar that plugs into your parallel port and you need to set your bios on your pc in the LPT port settings to ecp+eep so that the port can send and recieve normally its set just to print wich is a one way communication
If all of these is correct check inside the phone near charging block there is two small ic's try change them
Regards D.
Old 07-21-2004, 08:06   #7 (permalink)
mohd_anan's Avatar
Member: 56617
Thanks Meter: 4
Sir...
Thank u so much. I have GRIFFIN and DEJAN too.
I tried the 6210 cable coming with Dejan but failed and With 6310 coming with griffin but also failed I'll try changing the 2 ic's which u mentioned BUT first I'll check the service manuall for a pic SO u can confirm for me them before i remove
Thank u 4 ur coop.
Have a very GOOD DAY
Old 07-21-2004, 08:28   #8 (permalink)
mohd_anan's Avatar
Member: 56617
Thanks Meter: 4
Which ic u mean ?
Find the attached pic please and tell me which 2 ic's u mean
Lg-kp-115 which cable to use for flash subra007 Infinity-Box 6 04-13-2012 21:40
Which cable to use for flash or unlock this tv phone Shantobhai Infinity-Box 4 07-24-2009 15:45
M620 which cable to use for flash whith ustpro2? Shantobhai UST Pro II 7 07-09-2009 09:07
Can Any Body Tell Me Which Cable Is Used For X550 rajan nishchal UST Pro II 1 08-04-2007 17:16
can someone tell me with iles to use for z140 after89 Samsung (USB-Smart) 1 06-10-2006 13:45
Page generated in 0.30632 seconds with 9 queries
