12-21-2009, 05:09 | #1 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1188240 Status: Offline Thanks Meter: 1 | Can't revive Nokia E71-2 with JAF 1.98.62 I googled everything and stumbled across the JAF guide to revive my phone. At first I had issues with the program because it could not locate "ini files" .. I did a little more research and downloaded a JAF version 1.98.64 and it came with a few INI files that I copied over and pasted into my: C:\Program Files\Nokia\Phoenix\Products\RM-357 and C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-357 The files that are in these two folders are identical and are pitured below: I was then able to begin the flashing process, but it simply would not finish. This is what I get: JAF version 1.98.62 Detected PKEY: 90009699 Card life counter: 99.99% P-key nokia module version 01.02 FBUS INTERFACE NOT CONNECTED!!! USB Cable Driver version: 7.1.22.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-357\ Searching for default location of ini... Checking path: \Products\RM-357\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-357\ Scanning ini files... Searching for default location of ini... Checking path: \Products\RM-357\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-357\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-357\rm346_200.21.118_prd.c00 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-357\rm357_200.21.118_prd.v236 CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-357\rm357_200.21.118.236U APE Variant file: NONE Detected P-KEY: 90009699 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Sending RAW loader... Using 006.044.048 Elf2flash 08.20.000 CMT RAW loader... Patching RAW boot step1... Patching RAW boot step2... Patching RAW boot step3... Sending RAW Loader... ....................Loader Sent! Stage 2 starting..............Phone prepared OK! Waiting for the phone to boot... Searching for phone... Status byte: 0600 Selecting CMT flash...Result: 0000 Phone is in flash mode... CMT blocks: 800, APE blocks: 0 Erasing cmt... Processing C:\Program Files\Nokia\Phoenix\Products\RM-357\rm346_200.21.118_prd.c00... Erasing cmt zone 00040000 - 007FFFFF ... Erase result: 0000 Erasing cmt zone 00A00000 - 0759FFFF ... Erase result: 0000 Erasing cmt zone 0F1C0000 - 0F8BFFFF ... Erase result: 0000 Partition result: 0014 Partition result: 0014 Partition result: 0014 Processing C:\Program Files\Nokia\Phoenix\Products\RM-357\rm357_200.21.118_prd.v236... Erasing cmt zone 05420000 - 0759FFFF ... Erase result: 0000 Partition result: 0014 Processing C:\Program Files\Nokia\Phoenix\Products\RM-357\rm357_200.21.118.236U... Partition result: 0014 Send CMT CFG... Writing cmt... Processing C:\Program Files\Nokia\Phoenix\Products\RM-357\rm346_200.21.118_prd.c00... Sending CMT HASH for ADA Sending CMT HASH for KEYS Sending CMT HASH for PRIMAPP Sending CMT HASH for RAP3NAND Sending CMT HASH for PASUBTOC cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending... cmt->PAPUB keys already sent... Sending CMT HASH for SOS*UPDAPP Sending CMT HASH for SOS*DSP0 Sending CMT HASH for SOS*ISASW Sending CMT HASH for SOS*CORE Sending CMT HASH for SOS+ROFS Processing C:\Program Files\Nokia\Phoenix\Products\RM-357\rm357_200.21.118_prd.v236... Sending CMT HASH for SOS+ROFX Write result 27: 1701 Processing C:\Program Files\Nokia\Phoenix\Products\RM-357\rm357_200.21.118.236U... Rebooting... Finishing CMT session... Restarting CMT... Pooling phone... Phone not found... Second try... Phone not found... Done! So as you can see, it gets stopped at the "pooling pone" and it cannot find my phone. What seems to be the problem? HELP!! |
The Following User Says Thank You to ymmijbao For This Useful Post: |
JAF PKEY Expansion - working with JAF 1.98.62 | lalitjsraks | BB5KING | 64 | 04-17-2012 09:57 |
