10-15-2004, 16:01 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Location: SLOVAKIA Age: 46
Member: 86757 Status: Offline Thanks Meter: 12 | Changed glued IC. |
10-15-2004, 20:19 | #2 (permalink) |
Junior Member Join Date: Aug 2004 Age: 45
Member: 77186 Status: Offline Thanks Meter: 1 | sir, 1. you need tools to do that..BGA rework station, tweezers, flux, solder assist, soldering gun, soldering wick, cutter and new UEM. 2. clamp the board, so when you pop up the UEM the board will not move. 3. heat the UEM (only), so the other parts will not damage. until the balls is melted. ( i think, you know if it is melted) 4. pop or lift it up the UEM with tip of your cutter. (your cutter must be sharp and tiped.) 5. after you pop it or lift it up. take it with tweezer... 6. you will see the lift over of glue and lead. (First) clean the lead using solding gun and soldering wick and then try to clean the glue by using you your solder assist or your cutter by applying a small amount of heat. ( becare full of the pattern not to lift) 7. clean it, and replace the UEM. ( i forgot, you need a software to fix the IMEI on your UEM. UFSx, Griffin or anything that can fix the IMEI) 8. hope that it help you..... 9. know more here.. http://forum.gsmhosting.com/vbb/showthread.php?t=157093 regards |
10-18-2004, 10:40 | #3 (permalink) | |
Member: 86757 Status: Offline Thanks Meter: 12 | Quote:
One more Thank you! regards | |
10-22-2004, 14:44 | #6 (permalink) | |
Insane Poster Join Date: Apr 2001
Member: 4024 Status: Offline Thanks Meter: 0 | Quote:
--* video clip on how to remove glued IC *-- | -KimoAlex- | Nokia Hardware & Hardware Repair | 2 | 03-15-2006 15:45 |
video clip on how to remove glued IC! | eddierasta | Nokia Hardware & Hardware Repair | 5 | 02-10-2006 13:37 |
Opening GLUed IC | j2000 | Main Sales Section | 0 | 04-04-2005 21:28 |
special liquid for removing glued IC wanted! | sky master | Wanted Products | 2 | 07-23-2004 08:01 |
Glued IC | celtec | Nokia Hardware & Hardware Repair | 16 | 07-13-2004 14:25 |
