08-25-2004, 12:54 | #1 (permalink) |
Junior Member Join Date: Aug 2004 Location: australia Age: 44
Member: 78709 Status: Offline Thanks Meter: 0 | changing imei |
08-28-2004, 15:40 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: United States
Member: 51453 Status: Offline Thanks Meter: 729 | use hot air. before you do this put a flux on your uem so that your board will not be damage, after pulling out the uem clean the board with soldering iron where there are some leads left on the board, then after that put a flux on the board, before you put your new uem . there a little marker on the board ,where you could [aline] your uem ,then use your hotair with a mid air & mid heat, after that rebuild your imei....now you have change your imei b,r sherwin |
mtk change imei tool,supper 6223\6225\6226\mt6229 and supper change two imei | zhulianqi | Chinese Models & Cloned Phones | 22 | 02-11-2012 08:13 |
change imei on k750i and still the same imei has not change | KHEANG | MT-BOX | 4 | 12-24-2005 10:13 |
Change IMEI on DCT4/WD2 phones without change UEM chip! | chaval18 | Nokia Hardware & Hardware Repair | 11 | 04-26-2004 22:43 |
This guy claims that he's soft can change imei in DCT4 with out change of UEM!!! | Gsmhq | Nokia Multimedia | 2 | 10-25-2003 10:21 |
Need to change LP or downgrade C35 v.21 whitout change IMEI (need LP4) | maks | x1x to x45/x50 | 2 | 10-24-2001 07:37 |
