03-20-2006, 21:25 | #1 (permalink) |
No Life Poster Join Date: May 2002 Location: distant galaxy Age: 50
Member: 12386 Status: Offline Thanks Meter: 18 | charging fuse track damage i have a 6230 which wont charge tried to change the fuse. now the track on one side is damaged is there anyway repairing it. or any pictures please. thanks jab |
03-21-2006, 08:17 | #2 (permalink) | |
Freak Poster Join Date: Dec 2005 Age: 44
Member: 214350 Status: Offline Thanks Meter: 17 | Quote:
but if you was useing too much heat iorn tip that damages the track you can rebuild it . | |
03-22-2006, 11:23 | #4 (permalink) |
Member: 214350 Status: Offline Thanks Meter: 17 | OK all you need is to prepair the area equivalent of the damaged area from any old electronic components like pads commectors etc from any source , cut it then clean well the area of the old track , with epoxy fix it in place , then with flux put a tiny drop of solder at the end of the track. then bridge it to the nearest point useing an insulated bobine wire or semilar fine wire . |
04-25-2006, 16:10 | #7 (permalink) |
Junior Member Join Date: Apr 2006 Location: Canada Age: 49
Member: 259033 Status: Offline Thanks Meter: 0 | Fuse ****n Hi, I have ****n fuse in my 6230b (RH28). Phone will not charge. Checked incomming from charger - ok +/- pads inside - only 1.4v Could anyone point-show where the efuse is? How to replace it. (maybe picture or diagram of what to look for) Any help would be greatly appreciated. Thanks to anyone kind enough to help. |
1202 mic track damage | ameho0102 | Nokia Hardware & Hardware Repair | 15 | 08-21-2011 12:13 |
sony k750i keypad track damage i am uploading the damage area picture | faura | Sony Ericsson Hardware Repair | 5 | 09-02-2008 05:38 |
where is the charge fuse on the sharp gx10 | jab | Sharp | 3 | 09-25-2004 20:15 |
S55 Charging Fuse? | johny3310 | Siemens Hardware Repair Area | 2 | 05-20-2004 09:04 |
8310 charging fuse where | ali-g-string | Nokia Hardware & Hardware Repair | 6 | 04-16-2003 10:27 |
