02-05-2011, 11:10 | #1 (permalink) |
Banned Join Date: Jun 2009
Member: 1061826 Status: Offline Thanks Meter: 17 | charging is running is but not save the power.100% easy solution. No need to change thavo ic get take one television tunuer box pick diode from tuner box and join it direct from charging point to battery connector (+ve ) see the pic http://depositfiles.com/files/phnbo804c |
The Following 4 Users Say Thank You to dipenlama For This Useful Post: |
02-05-2011, 12:47 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Punjab , INDIA
Member: 153805 Status: Offline Thanks Meter: 325 | It is not safe solution.charger voltage is 6 to 8 volts.diode will drop only 0.7 volts.It will damage battery in few days.If battery dies during charging it may damage phone. |
The Following User Says Thank You to baldev For This Useful Post: |
02-05-2011, 13:30 | #6 (permalink) |
Member: 153805 Status: Offline Thanks Meter: 325 | Diode used in tuner are varactor (varicap) diode.they are used for electronic tuning.may heat up during charging.as charger voltage is droped to 4v only diode have to withstand all load. |
02-05-2011, 13:35 | #8 (permalink) |
Junior Member Join Date: Jun 2007 Location: philippines
Member: 535232 Status: Offline Thanks Meter: 22 | not good for me... sorry bro... when battery becomes deffective straight 6-7 volts will run through the phones battery... fone works for quite sometime because battery acts like a filter/capacitor... what happens when the battery suddenly dies... or when you try to switch it w/o batt but w/ charger plugged on it... staright 6-7 volts will run... 3.6v is the only running current most handset is capable of... |
02-05-2011, 14:31 | #9 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Cel_Phon - M.B.Din
Member: 328187 Status: Offline Thanks Meter: 1,687 | its not a safe solution man........but if u add a resistor with diode then it will work batter.... b coz a resistor resist a pressure of currant........ replacing of thavo is batter then all |
The Following User Says Thank You to imran zafar For This Useful Post: |
02-06-2011, 11:53 | #10 (permalink) |
Member: 1061826 Status: Offline Thanks Meter: 17 | Diode of television tuner box is suitable for all set .it shows charging and also give voltage to battery... and cut the voltage after battery full...I'm using these more than 4 years ...see tuner box in the fig |
02-06-2011, 22:09 | #13 (permalink) | |
Freak Poster Join Date: Apr 2009 Location: Intan HP
Member: 1002567 Status: Offline Sonork: abc Thanks Meter: 33 | Quote:
But nice post... keep it up... | |
02-07-2011, 05:46 | #14 (permalink) |
Member: 153805 Status: Offline Thanks Meter: 325 | Diode never cut voltage to battery when set stops showing charging.Diode can be used in chinese and other sets using 5v charger as diode will drop 0.7 volt and set will get only 4.3 volt you can put 4.7 to 10 ohms resistor in series with diode to drop some current.or best is use commonly available Battery charger(Here we call it JADDU) attach cable to it and give directly to battery no diode needed as it will cut charging to battery, when full. |
The Following 2 Users Say Thank You to baldev For This Useful Post: |
02-07-2011, 05:57 | #15 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | In electronics, a diode is a two-terminal electronic component that conducts electric current in only one direction he most common function of a diode is to allow an electric current to pass in one direction (called the diode's forward direction) while blocking current in the opposite direction (the reverse direction). no cut off system inside diode dont make funny post again |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
