05-30-2002, 20:20 | #1 (permalink) |
Major Poster Join Date: May 2002 Location: south africa
Member: 12134 Status: Offline Thanks Meter: 1 | cobba repair for dtc3 with 0000f help i have a nokia 3310 which had contact service . even after flashing and updating faid id it is not repaired can someone tell me how to programm cobba thanx in adv pd |
05-30-2002, 22:18 | #2 (permalink) |
Freak Poster Join Date: Mar 2001
Member: 3526 Status: Offline Thanks Meter: 2 | I suggest you remove the cobba from the board and replace it if it has a cobba id of 000000F. Or if you do not have a new cobba reball the cobba and replace it onto the board. Probably cobba has bad board contact. |
05-31-2002, 20:29 | #3 (permalink) |
No Life Poster Join Date: Sep 1999 Location: Europe Age: 43
Member: 461 Status: Offline Thanks Meter: 2 | try put good cobba and check -> cobba vs pcb board contact(all pins) And check components what's stay around cobba chip to visual diffect. And have good luck ! |
06-26-2002, 15:11 | #5 (permalink) |
Junior Member Join Date: Jun 2002 Location: Malaysia Age: 55
Member: 13245 Status: Offline Thanks Meter: 1 | change cobba and the change ccont if doesnt work use eeprom tool 3.1 and test the DSP if its ok then check the small chip near cobba is it and chip missing if u use eeprom tool to test the DSP if the program pop up DSP ALIVE FAIL <== then u have to change CPU |
07-17-2002, 17:47 | #6 (permalink) |
Member: 12134 Status: Offline Thanks Meter: 1 | 10x guys heloo thanx a million for the replys.after changing cobba i managed to break contact service but the cobba id still shows ooooo i have tried on four of them withoyt any results anyways some ones bound to stumble on the solution himself i will wait for a affirmative tested reply tiil then cheers! |
File lang vietnamese for KG800 with UFS.Help me . | levan1104 | LG | 1 | 02-07-2007 05:58 |
Repair C210 Moto with jupiter *****HELP NEEDED | Ja\/\/aD | Various CDMA/TDMA Cell Phones | 0 | 12-06-2006 08:43 |
need help with imei repair for E720 | maxking | Twisterflasher | 2 | 11-27-2005 14:56 |
Help for fullflash repair for emmibox++ | smanetton2 | Motorola Old Legacy (EMMI) | 1 | 09-01-2003 07:29 |
Help repair dead BF4 with wrong unlocking | bcnboy | BF, BG, TH, BHx Series | 3 | 05-31-2003 13:35 |
