Old 04-10-2004, 12:59   #1 (permalink)
Member: 61249
Connections Under IC
Hello Everybody,,,
I am mobile technician, i have replaced one UEM Ic in 6610
but still it is not power On.
So any body can help me to know, how to make sure the micro BGaA balls connectiuons under UEM Ic are OK.
I need same technics for UPP, Flash, SRAM ICs
Best Regards
Jem
Old 04-10-2004, 15:20   #2 (permalink)
Member: 44658
Are you sure that if you change the UEM, it WILL fix the fault?
Have you tried flashing the phone?
What program you using...
Have you probed the phone at all....
Best bet to check if UEM is down, is to heat it up, with heat gun (hakko) and with a microscope, look under at the UEM, and you'll see it move slightly, (that indicates that the solder balls under the UEM, have made a connection and solder is flowing)
thanks
Old 04-11-2004, 12:14   #3 (permalink)
Member: 61249
Smile
Hello Sir,
Thanx for ur reply.
I replaced the UEM using BGA Rework machine.
Before change IC i tried flashing using Pheonix.
It shown NAK Aknowledge fail.
As per the service manual i found it is because of UEM.
I replaced UEM, now it shows 'TXD Line high".
So can u please help me to know how to check continuuity for UEM by Multimeter.
Best Regards
Jem
Old 04-11-2004, 15:35   #4 (permalink)
Member: 44658
Hi
I use these guidelines for phoenix program, flash fails:
TXD Line High - change UEM
TXD Line Low - change UPP
Ms ID Failure - change flash prom
MAD NAK Aknowledgement failure - change UPP
Beings you've changed the UEM already using the BGA rework machine, and to your visible eye, the UEM change was all ok.
Best bet is to go for the UPP....
Old 04-13-2004, 07:39   #5 (permalink)
Member: 61249
Smile
Hello Sir,
Thanx for ur guidelines.
As i am new in this field, i need guidelines from experienced engineers like u.
I will try ur tips.
Thanx alot.
Jemshy
Old 04-13-2004, 07:46   #6 (permalink)
Member: 61249
thanx
Hello Sir,
I will try ur tips.
Thanx alot.
Jemshy
..::n70 Prints Under Keypad Ic Are Damaged::.. HUM Nokia Hardware & Hardware Repair 5 06-28-2008 17:03
1110 2 tracks missed under light ic hany elsaghir f Nokia Hardware & Hardware Repair 6 03-07-2007 13:45
1110 with 2 damaged pins under light ic hany elsaghir f Nokia Hardware & Hardware Repair 2 01-15-2007 20:05
5110 very hot under charge ic "not charging" eureka8888 Nokia Hardware & Hardware Repair 2 05-17-2002 21:52
8210 glue under ccont bga ic digipulse Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 03-02-2002 20:21
Page generated in 0.29081 seconds with 8 queries
