09-28-2005, 15:05 | #1 (permalink) |
No Life Poster Join Date: Apr 2003
Member: 26066 Status: Offline Sonork: cooleyes Thanks Meter: 128 | Converting 2600b 850/1900 MHz rh60 To 2600-rh59 900/1800 MHz 100% Working Change component shown in picture Selct model 2600 and flash the phone erase Flash Start Address 01000000 End Address 013FFFFF then flash the phone with 2600 flash file write the attched pm file and then do Ui settings Phone is working ok on 900/1800Mhz Here are the phone details Before Flashing : MCU Sw: V 3.26 23-09-04 RH-60 (c) NMP 2600b PPM Sw: V 3.26 23-09-04 RH-60 (c) NMP 2600b UB Prd.Cd: 0519542 Bpr.Cd: 0516272 Pro.Sn: QE0170011 HW : 0616 PCI : UEM : 8 UPP : 4609 RFIC : 0300 DSP : PES1.14-@ LCD : pcf8833 IMEI : 010474-00-169834-4 SLconf: 001-01-00000000000 SLprof: 000000000000000-2 SLvar : 00DE0104740016983400 SLaux : 0002C0DE Provider: Test Equipment After Flashing MCU Sw: V 3.36 29-11-04 RH-59 (c) NMP 2600 PPM Sw: V 3.36 29-11-04 RH-59 (c) NMP 2600 IC Prd.Cd: 0512529 Bpr.Cd: 0511261 Pro.Sn: CAB940045 HW : 0552 PCI : UEM : 8 UPP : 4609 RFIC : 0300 DSP : TB1.11 LCD : pcf8833 IMEI : 010474-00-169834-4 SLconf: 001-01-00000000000 SLprof: 000000000000000-2 SLvar : 00000104740016983400 SLaux : 00023938 Last edited by cooleyes; 09-28-2005 at 16:32. |
The Following User Says Thank You to cooleyes For This Useful Post: |
09-28-2005, 16:34 | #3 (permalink) | |
Member: 26066 Status: Offline Sonork: cooleyes Thanks Meter: 128 | Quote:
yes it is working 100% i have post the details of one phone result also and it is working | |
10-02-2005, 02:23 | #5 (permalink) |
Major Poster Join Date: Mar 2004
Member: 60398 Status: Offline Thanks Meter: 2 | Using Cooleyes procedure, I've converted a Nokia Tracfone 2600b, but after full flash, the phone blinks and hangs. I used both 3.36 and 4.42 version of 2600 and flash file and flash a full RH59 PM. I've tried to full earse it using 2600 erase file and the address given by cooleyes, but it does't work. Do you have asuggestion how it will be solved? BTW , I used 6510 filter and 3530 filters but both filters still wo'nt work. Thanks for your response. |
03-16-2006, 00:57 | #12 (permalink) | |
we are here to help each other | |
04-08-2006, 23:52 | #13 (permalink) |
Junior Member Join Date: Aug 2005 Age: 41
Member: 172153 Status: Offline Thanks Meter: 1 | I want to do it but form 2600 to 2600b i got one nokia 2600 but it dosnt seem to work here cuz its 900/1800 and i need 850/1900 can u help me please thanks in advance. |
05-13-2006, 00:26 | #14 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: Land of Lakes and Volcanoes Age: 51
Member: 111014 Status: Offline Thanks Meter: 132 | Quote:
I have UFS3 Tornado, I have 2600 tracfone, I managed to unlock this phone but always I get air tank prepaid thing. I'm aware If I flash this phone with unbranded flash, imei would go in ??????????????????????????4. Do you think this pm file can fix this problem? Thanks BR | |
05-23-2006, 14:31 | #15 (permalink) |
Freak Poster Join Date: Mar 2004 Location: United Arab Emirates Age: 33
Member: 60500 Status: Offline Thanks Meter: 2 | can any one tell me tht how to convert 1600b to 1600 if sum one know thn plzzzzzzzzzzz let me know abt it by sending pm or post it here BR |
2610b 850/1900 mhz convert to 2610 900/1800 mhz | patric | Nokia Hardware & Hardware Repair | 6 | 05-26-2010 14:20 |
change network 850/1900 mhz in 900/1800 mhz nokia usa | zhuzh | Nokia Hardware & Hardware Repair | 4 | 01-24-2007 12:33 |
How tp convert Motorola T720 with 850-1900 to 900-1800 mhz? | Chryse | Motorola P2k | 23 | 10-17-2004 07:41 |
Possible to convert GSM 850/1900 phone to 900/1800? | blackie | Nokia Hardware & Hardware Repair | 5 | 04-02-2004 12:45 |
how to convert t720 850/1900 to 900/1800? | ryumahon | Motorola P2k | 2 | 01-13-2004 13:00 |
