-   Nokia Hardware & Hardware Repair (http://forum.gsmhosting.com/vbb/f148/)
-   -   Damaged solder pads ? Is there any way to repair them ? (http://forum.gsmhosting.com/vbb/f148/damaged-solder-pads-there-any-way-repair-them-69960/)
simbirley 01-21-2003 14:23
People keep asking me if i can repair damaged solder pads where leds have been ripped off the board or where power switches have been pulled off.
Is there anyway to make the solder stick to the contact ?
Burnt Cobba 01-21-2003 15:08
one way to do it is use some super glue to stick the new acting pad. This however is according to where you are using it. If it is the switch then it msut be strongly and firmly held else it wil lgive way.
g luck
al
baraka42 01-21-2003 17:15
hi burnt ?
super glue is conductive ? what about connection from
x y z part ?
to simbirley,
i use diod's or resister's thick wire. one side at pcb's ground
and other at switche's ground leg. then second to supply
and then super glue.
willy 01-21-2003 19:27
Re: Damaged solder pads ? Is there any way to repair them ?
simbirley
might you have to search it first . and you can read this:
http://forum.gsmhosting.com/vbb/show...threadid=68845
Willy
Page generated in 0.14869 seconds with 5 queries
