01-06-2004, 21:02 | #1 (permalink) |
No Life Poster Join Date: Jan 2001 Location: France/Martinica/CPU Age: 45
Member: 3026 Status: Offline Sonork: 100.1602750 Thanks Meter: 102 | dead 6510 after flashing when erasing flash i have timeout respond now the phone is dead where is the problem? i reflow the uem, the flash no solution ? wbr |
01-06-2004, 23:05 | #2 (permalink) |
No Life Poster Join Date: Feb 2002
Member: 9428 Status: Offline Thanks Meter: 120 | did you try flashing again before jumping to conclusions?.....uem ic is heat sensitive so you might have killed it........if this is the case you need to change to new one and rebuild imei......and if phone still not powering up then change flash ic.....and try flashing again. hopes this solves your problem. br amit @ cf4u |
01-07-2004, 05:26 | #4 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | it is better to try to re flash again not jump to the flash ic changing . if not. may b the flash ic not fit well in its position or you were not reflow the uem well . please if you can remove the two ic.s you reflowed befor and check the balls under it and use flux to re ball the balls on board . this with mid heat and low air its take time but safe to board .. then re fit the two ic,s with no much flux ( i use no clean flux ) and sure its fit in its place try to re flash after the board totaly in normal temprature .. if not go to the hard way and change the two i.cs br. |
Need Help Dead V635 After Flash with V600 Flash (i didn't do it) | g0den99 | Motorola P2k | 3 | 10-08-2005 23:58 |
6510 After flashing works until restart... | rango | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 09-14-2003 04:53 |
dead t192 after FLASHING with bad flash file | zdob | Motorola Old Legacy (EMMI) | 5 | 07-02-2002 18:30 |
dead t280 after flash with free flash | tkerek | Motorola P2k | 0 | 05-26-2002 16:22 |
Dead 3699 after flashing | unlockerbh | Motorola Old Legacy (EMMI) | 0 | 08-22-2001 17:49 |
