01-29-2003, 12:44 | #1 (permalink) |
Freak Poster Join Date: Apr 2001
Member: 4398 Status: Offline Thanks Meter: 1 | 3310 - some keys dont work numbers 1,6,9,0 there is no corrosion or any water damaged on the phone. the phone has had leds fitted but i cant see any damage from them. when you press key 1 sometimes it brings up number 4 on the display. does anybody know what this is and how to fix it, i only have knowledge of reflowing, ledding, i cant resolder components on the board, thanks for your time. |
01-29-2003, 12:48 | #2 (permalink) |
No Life Poster Join Date: Aug 2001 Location: P A K I S T A N _____________ Age: 40
Member: 5932 Status: Offline Thanks Meter: 1,694 | Its a 70% MAD2 CPU problem or 10% chances Lines breaks to CPU. Download service Manual from Landy page or compare Keys to other board. Best Regards, Wahab |
01-29-2003, 16:18 | #3 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Philippines
Member: 4274 Status: Offline Thanks Meter: 18 | @simbirley: try to flash phone with good or fresh PPM+MCU file... if still the same try to check or replace R414, R415 and V415... or do some continuity test between keys grouping... keys outer circle: Clear/1/4/7/* = in group and goes to R415 and pin 5 of V415 0/6/9/# = in group and goes to R414 and pin 4 of V415 if after some checking/replacing of components and problem still the same try to reflow or apply a minimal heat underneath (heat up on PCB) the mad... just be careful in heating up the mad... |
K700i some key dont work | jamohaki | Sony Ericsson Hardware Repair | 1 | 05-04-2006 15:09 |
n620 some keys dont work! | GSM-Searcher | Samsung Hardware Repair | 0 | 02-04-2006 23:28 |
T610 some keys dont work | wim2000 | Sony Ericsson Hardware Repair | 0 | 01-18-2006 20:10 |
9210 Some Keys Dont Work | jamohaki | Nokia Hardware & Hardware Repair | 1 | 01-17-2006 07:43 |
d500, some keys dont work... | André_F | Samsung Hardware Repair | 7 | 10-28-2005 12:22 |
