dead E90 plz help me I have a problem of the E90 which is dead flashed. if u plag in a charger its shows charging but it can not switch on |
try to flash with jafbox . |
charge your phone with org. charger for 6 to 12 hours then power on an post log |
@twaha.segawa@gm Is it show local mode on software?????????? post log. |
Battery is showing voltage then try to flash again.otherwise might be UEM problem. |
yes it shows and it can flash upto the end. but switch it on is a problem. I replaced UI also it was giving me the same thing. |
Hi Bro U Falsh The Same Version Whit Mt-box And Then Post Result Ok Before 3 Week's Ago I Flash The Same Problem I Flash The Same Version And Then My Phon Is Working 100% Ok The U Post Result Ok B.r Sherry Mobiles |
e 90 dead hi rudyab just check voltege of on/off switch if voltege is 2.5 to 3.5 then shot the on/off switch by twiser or change belt and post your result here |
bro just use JAF n E50 7 pin cable or write latest version of E50 |
It can be caused by software? |
try to flash with ub box try to flash with ub box |
200.34.73 v5.0 emea not found Quote:
i think that you are right,but i'm looking for this version and hav'nt found it in all box support : ra-6: 200.34.73 v5.0 emea. plz if any one can upload or give link i were thanksfull |
