11-10-2005, 20:51 | #1 (permalink) |
Junior Member Join Date: Nov 2005
Member: 197987 Status: Offline Thanks Meter: 0 | Dead ngage QD the problem is.. while playing a game..the phone just shut itself off.. I thought dat was due to low battery.. later wen i tried charging it.. Nuthing showed up.. I took to service centre nearby.. They tried flashing it.. Didnt work... The flashing process goes on till 70-80% then reports an error.. they repeated the method several times.. Nuthing worked.. 1 of the technicians told me dat the flasher IC is damaged... wat do I do..? |
06-08-2007, 15:22 | #4 (permalink) |
Junior Member Join Date: Dec 2006
Member: 407184 Status: Offline Thanks Meter: 2 | Please help my ngage qd totally dead here is a log file, please assist me Getting MCU ID MCU ID: 0x1081 FLASH ID0: 01007E00 -> AMD Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 01007E27 -> AMD Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 00000100 -> NOT USED Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C9 00 00 EA 70 01 00 EA 73 01 00 EA 76 01 00 EA Checking RAM for ALGO... Algo is ready... Checking FAID calculation... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Failed! Aborting! |
Ngage Qda convert to Ngage Qd | supremegsm | WD2 & APE (Symbian Phones) | 1 | 12-24-2007 08:20 |
ngage qd dead | tejasr | Nokia Hardware & Hardware Repair | 0 | 11-11-2006 15:41 |
NGage QD dead | qwerthj | Twisterflasher | 8 | 07-30-2006 20:23 |
Ngage And Ngage Qd Freezeeee | JeAn-cLeM | Nokia Hardware & Hardware Repair | 4 | 04-14-2005 14:38 |
Ngage QD | sjakie | UFS2 + UFS3-Tornadoflasher | 0 | 06-24-2004 18:28 |
