11-29-2003, 15:40 | #1 (permalink) |
Freak Poster Join Date: Aug 2001 Location: Gdynia, Poland Age: 46
Member: 6060 Status: Offline Thanks Meter: 0 | 3410 signal loose after 5 sec. I have dropped 3410. Phone register in network and after 5 second loose network. It is the same in 900 and 1800 MHz. I have changed PA but problem still the same. thanks for reply. |
11-30-2003, 12:44 | #5 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | OK.. Droped means a brocken thing.., for differential diagnoses 1- If the phone feels the available networks , that means that the rx section did not affectes.--> So we have to check Power-Ampl., Ant-Switch, and maybe cobba brocken balls. 2- If the phone doesn't feel the networks , that means Incomeing Rx path---> Check Ant-pad could be brocken, Ant-Sw. could have a brocken pins at the base of it, filter crystals, and also maybe a brocken balls nder Hagar. |
12-07-2003, 06:11 | #11 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | Use Wintesla and Go to RF controls and try to let your phone transmit at power level 5. If you put flashing keychain and it starts to blink then TX is ok. Tx ok means your PA is working. If your PA is new, then you would have to check power line to PA from Bat +. Might be line cut (water damaged) If lines are ok then your PA might not be working. |
1112 imei change No signal off after 30 sec | Kamijeeawan | Universalbox | 18 | 08-10-2009 07:47 |
8330 signal drop after few secs ... ?? | TRABEL | LG | 4 | 08-16-2005 23:31 |
T65 reset after 5 sec | misel | Sony Ericsson | 4 | 05-30-2003 00:16 |
No signal after 5 secs. | laxxe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 03-16-2002 20:49 |
C25 - "wrong soft " and shutdown after 5 sec | Name | x1x to x45/x50 | 15 | 12-09-2000 20:24 |
