01-15-2015, 16:30 | #1 (permalink) |
Freak Poster Join Date: Oct 2005 Age: 41
Member: 188715 Status: Offline Thanks Meter: 31 | Nokia N95 keypad lock/unlock by itself *Changed the flex cable (it was broken) - problem not solved *Removed the magnet - problem not solved *If the slide is opened, there is no problem *If the slide mechanism is closed, the keypad lock/unlock by itself What should i do? I need help! Thanks! |
01-15-2015, 17:17 | #2 (permalink) |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | When slide mechanasm is in closed position, Under the magnet..... On Main Board you can find a IC. I think its near camera switch.....(idont have schematic or diagram) Check or replace it |
01-15-2015, 17:50 | #3 (permalink) |
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | slide sensor Your slide sensor is here.. http://www.4shared.com/download/DBCG....JPG?lgfp=1000 check or replace... |
01-15-2015, 19:35 | #5 (permalink) |
Member: 188715 Status: Offline Thanks Meter: 31 | Sorry for double post, but i cannot edit the previous message. On the other side of PCB, between volume keys, there is one more sensor - exactly like that one near camera button. So, i changed both sensors and now all is fine. I hope :P |
