03-13-2002, 07:55 | #1 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Leon
Member: 8804 Status: Offline Thanks Meter: 4 | Drop Signal, Causes & solutions. thank you. |
03-13-2002, 19:03 | #2 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Italy
Member: 7301 Status: Offline Thanks Meter: 0 | I'm not an expert of NOKIA phones, but I know that the most common cause of signal dropping and distorced audio are broken balls undr BGA COBBA IC . It's true expecially on NOKIA 3210... for other phones like 8210 and 3310/30 the cause could also be the HAGAR IC, or the TX/RX switch near the PA. If someone knows more is welcome.... |
03-20-2002, 02:06 | #5 (permalink) |
Freak Poster Join Date: Jul 2000 Location: Behind the Wall
Member: 1778 Status: Offline Thanks Meter: 0 | Hi! In most cases the drop signal problem is caused by bad soldering or damaged soldering under BGA ICs. For more phones it is important to check soldering under RF ICs, DSP and power supply ICs. For Nokia this is HAGAR (SUMMA for olders), COBBA and CCONT. Be ware of overheating. You will get best results after desolder ICs, make new balls under ICs and resolder back to PCB. For good solderings, use Philips soldering paste. For cleaning under ICs, use methyl alchochol (poyson!!!) and for cleaning pads on PCB use orthophosphorus acid. Clean with destilated water and dry with hair dryer for at least 30 minutes. To all I wish good luck! Assen |
03-25-2002, 03:31 | #6 (permalink) |
Junior Member Join Date: Mar 2002 Location: Leicester,England
Member: 10413 Status: Offline Thanks Meter: 0 | 6210 My signal problems were caused by the ext antenna socket on the rear of the phone.The changeover switch was faulty so i linked the socket out and it now works 100% Dave |
3610 NAM-1 No signal or Drop signal. | hhhhhh111111 | Nokia Hardware & Hardware Repair | 3 | 06-16-2010 23:37 |
3610 NAM-1 no signal or drop signal | hhhhhh111111 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-31-2007 15:18 |
nokia 1100,2300 perfect solution for dropping signal | noktune_win | Nokia Hardware & Hardware Repair | 2 | 10-14-2006 21:13 |
3310 DROPPED SIGNAL "no signal "AFTER FEW SECONDS | eng.hamdow | Nokia Hardware & Hardware Repair | 3 | 06-14-2005 11:12 |
SONY dropping signal ..repair | sigkill | Sony | 0 | 12-03-2001 11:56 |
