Old 02-18-2012, 04:49   #1 (permalink)
Registered User
Member: 1450442
Sonork: 15139300
Thanks Meter: 69
e-52-1 rm-469 only vibrate...please help
e-52-1 rm-469 only vibrate...please help.im flash all ready high,r virson.but same problem.
The Following User Says Thank You to m.jony2008 For This Useful Post:
Old 02-18-2012, 05:58   #2 (permalink)
Registered User
Member: 1450442
Sonork: 15139300
Thanks Meter: 69
please any boos ans: me.urgent
Old 02-18-2012, 09:08   #3 (permalink)
Dipankor-ctg's Avatar
Member: 1541551
Sonork: +965 99095810
Thanks Meter: 4,698
update virson now flash problem solve now try
Nokia E52 RM-469 firmware 31.012
The Following 2 Users Say Thank You to Dipankor-ctg For This Useful Post:
Old 02-18-2012, 09:14   #4 (permalink)
windman8's Avatar
Member: 614801
Thanks Meter: 134
earthquake the two i.c bro
The Following User Says Thank You to windman8 For This Useful Post:
Old 02-18-2012, 09:16   #5 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,247
try flash this version & post result
http://nds2.fds-fire.nokia.com/fdp/i...7/076713v3.pcx
http://nds2.fds-fire.nokia.com/fdp/i...g_MoMe_001.xml
http://nds2.fds-fire.nokia.com/p/d/f..._prd.core.fpsx
http://nds2.fds-fire.nokia.com/p/d/f...prd.rofs2.fpsx
http://nds2.fds-fire.nokia.com/p/d/f...prd.rofs3.fpsx
http://nds2.fds-fire.nokia.com/p/d/f...0_prd.uda.fpsx
http://nds2.fds-fire.nokia.com/fdp/i...k23v0.091.fpsx
http://nds2.fds-fire.nokia.com/p/d/f...81.003_001.dcp
http://nds2.fds-fire.nokia.com/p/d/f..._signature.bin
http://nds2.fds-fire.nokia.com/p/d/f...81.003_001.vpl
The Following User Says Thank You to Nadeem Waris For This Useful Post:
Old 02-18-2012, 12:03   #6 (permalink)
Member: 583454
Thanks Meter: 80
hardware problem dear rehot pcb area near usb connector
The Following User Says Thank You to waqarN70 For This Useful Post:
Old 02-18-2012, 18:51   #7 (permalink)
Tabrez1's Avatar
Member: 1343156
Thanks Meter: 45
Bro change boot ic your pro 100% solve....
Old 02-18-2012, 20:53   #8 (permalink)
Member: 1439039
Thanks Meter: 20
change boot ic gazoo-power-
Old 02-19-2012, 06:30   #9 (permalink)
Registered User
Member: 1450442
Sonork: 15139300
Thanks Meter: 69
all boos i am flash.ok test mode ok.but normal mode not ok.
all boos i am flash.ok test mode ok.but normal mode not ok.please teel me
Old 02-19-2012, 07:05   #10 (permalink)
trinkaljuneja's Avatar
Member: 368590
Sonork: 100.1609194
Thanks Meter: 60
Thumbs up Try this
For e series blank , vibrating only , blank screen
try this solution
For e series try this solution
http://forum.gsmhosting.com/vbb/f311...8/#post8108927
http://forum.gsmhosting.com/vbb/f148...3/#post8107679
Old 02-20-2012, 00:46   #11 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
try this:
1st select this file in ppm
2nd flash ur phone with this file
3rd again flash ur phone with e52 flash files
done
post result
File Type: rar E66_blank_504KB_pmm_10.rar (611 Bytes, 333 views)
Old 02-21-2012, 05:54   #12 (permalink)
Registered User
Member: 1450442
Sonork: 15139300
Thanks Meter: 69
this model not e66.only e52-1.rm-469
Originally Posted by HUM View Post
try this:
done
post result
Old 02-21-2012, 08:07   #13 (permalink)
shy100's Avatar
Member: 954865
Thanks Meter: 650
no problem. select it in mcu window....i am not sure about this wil alive ur phone
Old 02-21-2012, 08:58   #14 (permalink)
irfanboss's Avatar
Member: 256247
Thanks Meter: 444
all set only vibrate slution 100% done
1)read full flash with best dongle (usb)
2)erase full flash
3)flash phone
4)write rpl in best dongle (dont select rpl best software take automatic)
5)open best software and click RESTORE SL after restore data best dongle make sim rpl
6)again write rpl (select sim.rpl )
7)if sd data is damage so u will repair with mx key
after this prociser only vibrate 100% ok .
if u agreed so plz click thanks button
IRFAN BOSS
Old 02-21-2012, 09:30   #15 (permalink)
Member: 274803
Thanks Meter: 23
where we got boot ic ??????
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.25166 seconds with 10 queries
