Old 12-11-2010, 19:10   #1 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 736
e 52 only vibrate
i have a e 52 only vibrate ,flashed with eno, and flash with latest firmware,,but same,,also ,heat upp,,and power,,but same,
what u say about this,,flash wit mt,,,cyclone,mxkey,,same,,,,,
any idea about this,e 52
Old 12-11-2010, 19:47   #2 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 736
all are sleeping...any idea.
Old 12-11-2010, 20:01   #3 (permalink)
Moderator
Nizda Mobile's Avatar
Member: 1464783
Thanks Meter: 1,069
try post log bro!,maybe someone cant help.
Old 12-11-2010, 20:23   #4 (permalink)
Moderator
Member: 1464783
Thanks Meter: 1,069
try rehot and shake a rap ic.
Old 12-11-2010, 20:35   #5 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 736
this is log,can not get info,bcause of blank,only vibrate...also heat and shake,rap ic,
Box is activated
Started box selftests procedure
USB Voltage 4.99v PASSED
MCU Voltage 3.29v PASSED
Core Voltage 1.79v PASSED
VBAT Voltage 0.61v PASSED
VBAT Voltage 4.92v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Internal Box VPP Enabled
VPP Voltage 4.92v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
Initializing FBUS...
All initialized - Ready to work
Scanning avaiable products...
Processing C:\Program Files\Nokia\Phoenix\Products\...
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\...
Found 46 products, Filtering BB5 Products - wait...
11 Products left after filtering. Ready.
Retrieving Variants for Product RM-469 (Nokia E52) - wait...
24 Variants Retrieved
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Processing rm469_052.003_prd.core.fpsx (CMT)...
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104
CMT_EM_ASIC_ID: 00001040
CMT_EM_ASIC_ID: 00001030
CMT_PUBLIC_ID: 257001156E6203444A51D38B26F462AC4245673A
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695
CMT_BOOT_ROM_CRC: 3E273BF6
CMT_SECURE_ROM_CRC: 37BE26FA
CMT Ready!
rm469_052.003_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
Searching for BootCode: DualLine 32Bit
RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.10.34.1, Algo: BB5
Flashbus Write baud set to 650Kbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0020004000000031, ST, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported
RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.10.34.1, Algo: XSR 1.6
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 85F252E351E225CAFC4DFBC8041EABD2823E3500
Flashbus Write baud set to 5.0Mbits
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00020000-0x0003FFFF, ONENAND
EraseArea[0,CMT]: 0x00060000-0x004DFFFF, ONENAND
EraseArea[0,CMT]: 0x008E0000-0x0B13FFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 0.797s
Writing all blocks...
TurboCache Loaded!
Writing CMT ADA Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT SOS+PMML Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT GENIO_INIT Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT LDSP Certificate...
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
Programming Status OK!
All blocks written OK! Time taken 117.281s
Flashing Speed: 7223.71 kBit/S
Restarting MCU...
Processing rm469_052.003_prd.core.fpsx (APE)...
Processing RM469_ENO_09w23v0.a078.01.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM469_ENO_09w23v0.a078.01.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Certificates OK
EraseArea[0,CMT]: 0x004E0000-0x008DFFFF, ONENAND
Erase taken 0.46s
TurboCache Loaded!
Writing CMT SOS*ENO Certificate...
All blocks written OK! Time taken 3.16s
Flashing Speed: 7057.14 kBit/S
Restarting MCU...
Processing RM469_ENO_09w23v0.a078.01.fpsx (APE)...
Processing rm469_052.003_12.01_SSA1_prd.rofs2.fpsx (CMT)...
Booting CMT...
CMT Ready!
rm469_052.003_12.01_SSA1_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
EraseArea[0,CMT]: 0x07340000-0x09CFFFFF, ONENAND
Erase taken 0.204s
TurboCache Loaded!
Writing CMT SOS+ROFS2 Certificate...
All blocks written OK! Time taken 44.281s
Flashing Speed: 7321.91 kBit/S
Restarting MCU...
Processing rm469_052.003_12.01_SSA1_prd.rofs2.fpsx (APE)...
Processing rm469_052.003_C00.01_DEFAULT_prd.rofs3.fpsx (CMT)...
Booting CMT...
CMT Ready!
rm469_052.003_C00.01_DEFAULT_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
EraseArea[0,CMT]: 0x09D00000-0x0B13FFFF, ONENAND
Erase taken 0.110s
TurboCache Loaded!
Writing CMT SOS+ROFS3 Certificate...
All blocks written OK! Time taken 8.797s
Flashing Speed: 7201.18 kBit/S
Restarting MCU...
Processing rm469_052.003_C00.01_DEFAULT_prd.rofs3.fpsx (APE)...
Processing rm469_052.003_U006.000_prd.uda.fpsx (CMT)...
Booting CMT...
CMT Ready!
rm469_052.003_U006.000_prd.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
EraseArea[0,CMT]: 0x0B140000-0x0F27FFFF, ONENAND
Erase taken 0.297s
TurboCache Loaded!
All blocks written OK! Time taken 5.500s
Flashing Speed: 7099.61 kBit/S
Restarting MCU...
Processing rm469_052.003_U006.000_prd.uda.fpsx (APE)...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Old 12-12-2010, 02:00   #6 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,228
remove back camera and try to power on
if still same remove charging ic
if still the same double ic faulty
The Following 2 Users Say Thank You to HUM For This Useful Post:
Old 12-12-2010, 09:35   #7 (permalink)
Member: 295762
Thanks Meter: 128
which ic do you mean "double ic"? can you give me picture?
5110/6110 after unlocking see only network to which it was locked and ... 2M Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 07-25-2000 01:51
Only MAX232 ??? AMIGO Nokia Hardware & Hardware Repair 7 04-12-2000 10:41
only 1800Mhz ?? dofie Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 01-17-2000 21:51
20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed spterminator Main Sales Section 0 08-08-1999 06:08
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 40 each 30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 06:46
Page generated in 0.39804 seconds with 8 queries
