Old 12-19-2012, 06:29   #1 (permalink)
ren_mglab's Avatar
Member: 1501033
Thanks Meter: 35
Exclamation e5 no light need help
good day to all anybody help me about e5 no light.
please give solution to solved it.. or give jumper ways
thanks in advance
Old 12-19-2012, 07:00   #2 (permalink)
ren_mglab's Avatar
Member: 1501033
Thanks Meter: 35
anybody help me.
action taken:
check lcd lines good
change coil no luck
change light ic no luck
what next? i'm waiting
Old 12-19-2012, 07:34   #3 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 7,629
thanks in advance
anybody help me.
action taken:
change coil no luck
Nokia E5-00 light problem
just look at the two pictures I show
see the display light jumper lines and its keypad lights
problems you may encounter can be completed
dont forget to click thank..!
File Type: jpg Nokia E5 display LIGHT jumper ways.jpg (116.2 KB, 861 views)
File Type: jpg Nokia E5 keypad light problem solution.jpg (116.6 KB, 769 views)
The Following User Says Thank You to d-Artigo For This Useful Post:
Old 12-19-2012, 07:48   #4 (permalink)
ren_mglab's Avatar
Member: 1501033
Thanks Meter: 35
thanks sir for your reply i check that line but the is good..
no lcd light but in keypad has a light..
i also change lcd but still no luck...
Old 12-19-2012, 08:39   #5 (permalink)
d-Artigo's Avatar
Member: 1573913
Thanks Meter: 7,629
see the picture show
check working voltage display driver led him on C2425 and C2426 = 1uF = 2.2 uF capacitor ... if both are still working well and issued a voltage ... change its display lamp driver
File Type: jpg Nokia E5 display LIGHT jumper ways.jpg (118.5 KB, 342 views)
Old 12-19-2012, 09:10   #6 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
Brother try to check this track if any damage then make jumper.. Post result..
The Following User Says Thank You to Sagitarious For This Useful Post:
Old 12-19-2012, 10:21   #7 (permalink)
anujc143's Avatar
Member: 1550704
Sonork: 100.1644808
Thanks Meter: 248
its note my solution post at by shijil...........
Old 12-20-2012, 00:48   #8 (permalink)
ren_mglab's Avatar
Member: 1501033
Thanks Meter: 35
thanks to all solution anujc143 sir i will try this today and i will post result thanks
Old 08-18-2014, 12:09   #9 (permalink)
Member: 1351441
Sonork: vijisari
c2425,c2426 this spare which board available please
Page generated in 0.20009 seconds with 9 queries
