E52 charging solution 100% tested i have e52 charging not show,but recognize if you plug in usb.. first i try to check charging terminal but working fine i check this http://i253.photobucket.com/albums/h...07/SHOT005.jpg its shorted... i change pearl ic or power ic same problem http://i253.photobucket.com/albums/h...07/SHOT001.jpg i tryied to search here but no solution this is your solution http://i253.photobucket.com/albums/h...07/SHOT004.jpg you can take it in n70 check in schematic c2012 press thanks botton please...;) |
Good solution !!! I`m tested this solution, phone repaired. Capacitor value is 1u0. Thanks. |
pls help 7510a sharger not support????????????????????????????????? |
Works! Very good finding ;) Thanx |
Charger now ok, tq bro. but usb still not detect |
gooooooooood thank you |
super work thanix so much sir |
thank you,good job!! |
thank you sir!!! good work!! keep it up!!! |
good job Thank You Byte ----- Cheap Hosting Web Hosting Services, Reseller Hosting, and Dedicated Servers by HostGator |
tested!100% good solution!thanck you |
its ok ............................tested |
Thanks alot........... |
Yes, for me work too. I havn't short in usb. But when plug charger, on display there is battery but not filling it. I change capacitor and all OK. Bravo for JASKY007. |
