10-02-2012, 23:08 | #1 (permalink) |
Freak Poster Join Date: Sep 2012 Location: south africa Age: 39
Member: 1813139 Status: Offline Thanks Meter: 45 | E52 local mode on software but only vibrate i have nokia e52 jus vibrating only but on the software is fine here is log ================================================ Basic Phone Information ================================================ MCU Version: V ICPR82_11w16.3.11 29-03-12 RM-469 (c) Nokia IMEI Plain : 355216037569376 IMEI Spare : A355216037569370 IMEI SV : 33552160375693757F Phone Model: Nokia E52-1 Category : Classic Phone Phone Type : RM-469 ================================================ Extended Phone Information ================================================ Product Serial Number: 0 Long Production SN : 0 MCU SW Version : V ICPR82_11w16.3.11 29-03-12 RM-469 (c) Nokia RFIC Version : |Vapaus_5.1 | Aura_?.? DSP Version : 11w52 Content : rm469_091.004_U006.000_prd AHNE Version : 11 APE SW Core Version : 091.004 Variant Version : 091.004091.004.02.01091.004.C00.01 APE Test Version : v0.a091 RETU Version : 40 TAHVO Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : C0:38:F9:A1:59:C1 Bluetooth ID : C0:38:F9:A1:4A:21 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED jus vibrate only thanx |
10-05-2012, 14:46 | #4 (permalink) |
No Life Poster Join Date: Sep 2007 Location: I /\/ D I /_\
Member: 580791 Status: Offline Sonork: 100.1623010 Thanks Meter: 103 | check bsi line 1st and battery connector post result............. |
The Following User Says Thank You to .::AKTYAGI::. For This Useful Post: |
10-05-2012, 14:56 | #5 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Brother, listen first download phone same product code flash file then flash it.if still same backup rpl and simlock 120 pm reset npc then check it still same condition? Full erase flash then flash it any version after flash put the battery then power on the phone phone is normal condition? Ah restore rpl only again to check with battery normal condition good restore simlock pm and repair sd also write 1 and 309pm enough but one think some phones after restore rpl phone go to dead you faced this problems you can send me rpl backup now you can try this methode i think phone hardware is good any problem with bsi line phone cant enter the loacl mode with fbus cable i hope this methdoe alive your phone |
