E63 Blue Display Problem Nokia E63 mobile which problem with Blue display. Mobile making incoming and outgoing call. i changed both display ic but problem still remain. have any solution ? please share here. Thanks. |
Try Change LCD Display bro. |
try to flash with blank ppm............ Quote:
i changed LCD but problem still same. |
1 Attachment(s) check this lcd way , also post result |
write blank ppm ur problem solved 100% |
but mobile making incoming and outgoing call so i this there is no need to write blank ppm. |
waiting for solution |
yes lcd ics are well. |
e63 cheng lcd shoket |
e63 blue display no incomeing no out plz he outgoing plz help |
try to flash with blank ppm............ |
1. If incoming and out going Ok then try Hardware a. check or change charging connector b. check or change display ic 2. If no incoming and outgoing Flash it with blank PM E66_blank_504KB_pmm_10.fpsx I got ok after write blank pm |
update this thread sir ok already ur mobile? |
