Old 05-15-2012, 08:03   #1 (permalink)
ravi mobile's Avatar
Member: 669673
Thanks Meter: 281
E63 Blue Display Problem
Nokia E63 mobile which problem with Blue display. Mobile making incoming and outgoing call. i changed both display ic but problem still remain.
have any solution ? please share here.
Thanks.
The Following User Says Thank You to ravi mobile For This Useful Post:
Old 05-15-2012, 09:34   #2 (permalink)
N.C.Erepola's Avatar
Member: 1615710
Sonork: 100.1647890
Thanks Meter: 185
Try Change LCD Display bro.
Old 05-15-2012, 09:45   #3 (permalink)
Absar_Global's Avatar
Member: 1442705
Thanks Meter: 702
try to flash with blank ppm............
Old 05-15-2012, 10:55   #4 (permalink)
Member: 669673
Thanks Meter: 281
i changed LCD but problem still same.
Old 05-15-2012, 11:18   #5 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,082
check this lcd way , also post result
File Type: jpg nokia e63 white blue screen display solution.jpg (34.0 KB, 350 views)
Old 05-15-2012, 11:39   #6 (permalink)
Member: 169399
Thanks Meter: 28
write blank ppm ur problem solved 100%
Old 05-15-2012, 12:14   #7 (permalink)
Member: 669673
Thanks Meter: 281
but mobile making incoming and outgoing call so i this there is no need to write blank ppm.
Old 05-15-2012, 17:58   #8 (permalink)
Member: 669673
Thanks Meter: 281
waiting for solution
Old 05-16-2012, 03:41   #9 (permalink)
Mehmood Riaz 1's Avatar
Member: 1737175
Sonork: 100.1667675
Thanks Meter: 3,074
are you sure that you placed lcd drivers[ics] well
Old 05-16-2012, 04:33   #10 (permalink)
Member: 669673
Thanks Meter: 281
yes lcd ics are well.
Old 05-16-2012, 07:48   #11 (permalink)
gsm reqest's Avatar
Member: 1399206
Sonork: reqest
Thanks Meter: 113
e63
cheng lcd shoket
Old 05-13-2013, 17:06   #12 (permalink)
Member: 1308472
Sonork: mohd_nadeem231
Thanks Meter: 10
e63 blue display no incomeing no out plz he outgoing plz help
Old 05-20-2013, 12:40   #13 (permalink)
Member: 1029677
Thanks Meter: 54
Old 07-17-2013, 14:49   #14 (permalink)
Member: 228358
Thanks Meter: 32
1. If incoming and out going Ok then try Hardware
a. check or change charging connector
b. check or change display ic
2. If no incoming and outgoing
Flash it with blank PM E66_blank_504KB_pmm_10.fpsx
I got ok after write blank pm
Old 01-28-2014, 03:05   #15 (permalink)
Member: 1400808
update this thread sir ok already ur mobile?
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 09:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 16:21
blue led? Michael Go Wanted Products 0 09-10-1999 01:57
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 01:44
Page generated in 0.40475 seconds with 9 queries
