GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Nokia Hardware & Hardware Repair (https://forum.gsmhosting.com/vbb/f148/)
-   -   e63 charging problem (https://forum.gsmhosting.com/vbb/f148/e63-charging-problem-1425418/)
luyanda 02-07-2012 15:49
e63 chargin problem when i open i found the glass next to l2000 is broken but all lines are still working fine and it show 4.31 v when you test but still
not charging
W.A 02-07-2012 16:33
1 Attachment(s)
not charging
Here's the Nokia E63 Not Charging Problem Solution, this solution simply shows the location of the charging components on E63 PCB board.
To fix a charging problem like "charger no response, or fake charging this solution may help. Just refer to the solution below and locate the highlighted components.
Nokia E63 Charging Problem Solution
Some simple hints to fix Not charging Problem On Nokia E63 handset:
Nokia E63 Charger No Response problem - it doesn't show or display battery charging indication when the charger is plug-in.
1. Try to use another working charger.
2. Check/replace the charging pin connector for possible damaged, bended or oxidation build up.
3. Clean the charging pin terminal contact pads on the PCB board.
4. Check the Fuse the coil and the diode, replace if found damaged.
Nokia E63 Fake Charging Problem - it shows or display a charging indication but the charge voltage doesn't stored or saved on the battery.
1. Try to replace or use another working phone's battery.
2. Check and clean the battery connector.
3. Reheat, rework or replace the BETTY IC.
4. If the problem still exists, try to rework the Power IC.
Nokia E63 Charger Not Supported Problem - it shows a "charger not supported error"on the display when the battery is plug in.
W.A 02-07-2012 16:42
1 Attachment(s)
not charging
or try this one...........................)))))))))))))::
aliyasinyaseen 05-22-2012 20:21
my e63 demo charging problem,i will change all components ,but not ready.my board have not diode prient..what i do?
Page generated in 0.09312 seconds with 6 queries
