02-07-2012, 15:49 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | e63 charging problem not charging |
02-07-2012, 16:33 | #2 (permalink) | |
Insane Poster Join Date: Jun 2011 Location: Hydeabad Sindh Age: 31
Member: 1602543 Status: Offline Sonork: 100.1612758 Thanks Meter: 23 | Quote:
Here's the Nokia E63 Not Charging Problem Solution, this solution simply shows the location of the charging components on E63 PCB board. To fix a charging problem like "charger no response, or fake charging this solution may help. Just refer to the solution below and locate the highlighted components. Nokia E63 Charging Problem Solution Some simple hints to fix Not charging Problem On Nokia E63 handset: Nokia E63 Charger No Response problem - it doesn't show or display battery charging indication when the charger is plug-in. 1. Try to use another working charger. 2. Check/replace the charging pin connector for possible damaged, bended or oxidation build up. 3. Clean the charging pin terminal contact pads on the PCB board. 4. Check the Fuse the coil and the diode, replace if found damaged. Nokia E63 Fake Charging Problem - it shows or display a charging indication but the charge voltage doesn't stored or saved on the battery. 1. Try to replace or use another working phone's battery. 2. Check and clean the battery connector. 3. Reheat, rework or replace the BETTY IC. 4. If the problem still exists, try to rework the Power IC. Nokia E63 Charger Not Supported Problem - it shows a "charger not supported error"on the display when the battery is plug in. | |
The Following User Says Thank You to W.A For This Useful Post: |
02-07-2012, 16:42 | #3 (permalink) | |
or try this one...........................))))))))))))):: | |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
