Old 12-17-2009, 08:45   #1 (permalink)
Member: 282510
Thanks Meter: 33
E63 display ic
anyone plzz tell me where does e63 dispaly ic located?
Old 12-17-2009, 08:47   #2 (permalink)
Member: 823633
Thanks Meter: 1,705
brother
check
the display ic is on top of the key pad connecter u have to break the shield it is inside
Old 12-17-2009, 09:37   #3 (permalink)
md.nazmul's Avatar
Member: 648428
Thanks Meter: 846
Some tip from a nokia e63 keypad malfunction, this set is water damaged as you can see in the image.
clean first then reheat or replace.
The Following 3 Users Say Thank You to md.nazmul For This Useful Post:
Old 03-03-2010, 08:01   #4 (permalink)
rawkiss's Avatar
Member: 997585
Thanks Meter: 17
i am confused. which one is display IC ?. can you show me the picture diagram of display ic?
Old 03-03-2010, 12:16   #5 (permalink)
kurd-gsm's Avatar
Member: 1167158
Thanks Meter: 1,723
nokia e63 displai solution by kurdish mobile
nokia e63 display solution by kurdish mobile
The Following 2 Users Say Thank You to kurd-gsm For This Useful Post:
Old 10-04-2010, 09:16   #6 (permalink)
=GsM_Angel='s Avatar
Member: 1062107
Thanks Meter: 544
Solution for white screen, blue scree, blank screen and garbled screen displays
The Following User Says Thank You to =GsM_Angel= For This Useful Post:
Old 07-02-2011, 11:23   #7 (permalink)
Member: 581417
Thanks Meter: 100
http://1.bp.********.com/_haRAPmO1Se...y+solution.jpg
The Following User Says Thank You to sabirsultan For This Useful Post:
here is trick for repair display without changing display ic rubel_chk007 Nokia Hardware & Hardware Repair 0 08-06-2009 05:43
help..which ic use for e65 display ic? CHAPRAN Nokia Hardware & Hardware Repair 0 06-08-2009 12:24
w 550i white display, where is display IC seeta Sony Ericsson Hardware Repair 5 06-30-2008 13:03
How to get datasheet of Nk 6600 display ic & SE K500 Charging ic .::AD Com::. Nokia Hardware & Hardware Repair 0 05-04-2007 15:06
Page generated in 0.25621 seconds with 10 queries
