Old 07-22-2007, 13:55   #1 (permalink)
Member: 207445
Thanks Meter: 19
3110 mic problem
I have nokia 3110c which mic doesnot work.pl help me.thanks
The Following 4 Users Say Thank You to honeytelecom For This Useful Post:
Old 07-22-2007, 19:37   #2 (permalink)
Member: 551914
make sure that the mic is working by using AVO
otherwise it may be from ic power
Old 02-13-2008, 06:41   #3 (permalink)
Member: 589515
Thanks Meter: 58
pls help me nok3110 mic not working
The Following User Says Thank You to smarttech For This Useful Post:
Old 02-14-2008, 10:23   #4 (permalink)
Member: 573139
Thanks Meter: 12
picture please...........................
The Following User Says Thank You to shahid_shimu For This Useful Post:
Old 02-14-2008, 10:27   #5 (permalink)
yargich's Avatar
Member: 28531
Thanks Meter: 90
chance mic use c65 or siemens mic
Old 02-14-2008, 10:32   #6 (permalink)
Member: 573139
Thanks Meter: 12
mic already ok But not work ............
Old 02-14-2008, 10:48   #7 (permalink)
Member: 185422
Thanks Meter: 41
look this!!! if not work change the headset conector
The Following 11 Users Say Thank You to georgegsmro For This Useful Post:
Old 02-14-2008, 12:16   #8 (permalink)
Member: 631153
[quote=georgegsmro;3087281]look this!!! if not work change the headset conector
Old 02-15-2008, 10:11   #9 (permalink)
Member: 185422
Thanks Meter: 41
[QUOTE=sabirne;3087507]
yes ,if not work jumper try to change the headset connector
Old 05-07-2008, 10:51   #10 (permalink)
Member: 761820
Sonork: 100.1594410
Thanks Meter: 30
Talking
THANX.... anybody test this???
Regard.... Tanzania
Old 05-07-2008, 10:54   #11 (permalink)
Member: 761820
Sonork: 100.1594410
Thanks Meter: 30
Talking
Boss i can not inlarge ur attached picture... please upload then to rapid share....
Regards..... Tanzania....
The Following User Says Thank You to xtream 08 For This Useful Post:
Old 07-01-2008, 06:03   #12 (permalink)
Member: 478132
Picture not clear.....
The Following User Says Thank You to myrajes For This Useful Post:
Old 07-01-2008, 08:51   #13 (permalink)
suntysunty's Avatar
Member: 226172
Thanks Meter: 946
very low voice generated when make this jumpers
The Following User Says Thank You to suntysunty For This Useful Post:
Old 12-17-2008, 20:09   #14 (permalink)
Member: 866249
thanksssssssssssssssssssssssssssssss
Old 12-18-2008, 02:36   #15 (permalink)
Member: 767784
Thanks Meter: 21
3110 mic
pictur is not clear.is any bdy have clear picture?
Nokia 3110.Mic problem masud_434 Nokia Hardware & Hardware Repair 3 12-13-2010 11:35
Need 3110 mic ic Jumpers broken_rules Nokia Hardware & Hardware Repair 6 08-22-2010 12:44
mic problem 3110 salotion kashantariq2002 Nokia Hardware & Hardware Repair 2 12-08-2009 11:12
3110 mic problem korabika82 Nokia Hardware & Hardware Repair 3 01-09-2009 18:42
3110 mic problem max_cool Nokia Base Band 5 ( BB-5 ) 3 03-18-2008 17:20
Page generated in 0.20910 seconds with 10 queries
