Old 05-19-2009, 14:25   #1 (permalink)
cheyn's Avatar
Member: 646368
Thanks Meter: 113
E65 freezing when memory card inside
e65 freezing after a while only when memory card is inside,i have done the software upgrade,problem is same.any advice how to solve the problem please.
Old 05-20-2009, 08:39   #2 (permalink)
luqmaan's Avatar
Member: 617428
Thanks Meter: 52
Format memory card data is corrupt or change the card problem solved easy now hey,dont forget to say thanks
Old 05-20-2009, 14:29   #3 (permalink)
cheyn's Avatar
Member: 646368
Thanks Meter: 113
jzk luqmaan for the reply,but iv changed many memory cards,even diff type of kb n gigs.and if you leave it in the phone for a while the lcd goes blank and only green light in the back ground.
Old 05-21-2009, 12:24   #4 (permalink)
luqmaan's Avatar
Member: 617428
Thanks Meter: 52
ok now we getting somewhere well in that case first you need to format the phone but remember this will erase all info the other way is to do a firmware update either use universal box or jaf or you can attempt the nokia online update(dangerous) and remember dont restore settings to the phone as it could be the settings that has a corrupt file. hope this helps you..
Old 05-22-2009, 10:51   #5 (permalink)
cheyn's Avatar
Member: 646368
Thanks Meter: 113
my first post says i did do a software upgrade,but i got the problem sorted,mmc reader was faulty,replaced the ic.anyway thanks for the reply.
Old 11-13-2009, 13:26   #6 (permalink)
IM8
Member: 694535
Thanks Meter: 70
same problem any ideea? di u solve the problem ?
Old 11-13-2009, 14:46   #7 (permalink)
s.s.s.s.'s Avatar
Member: 988641
Sonork: sanjay chaudhary
Thanks Meter: 342
bro,
your problem in mmc ic rehot or change it..............................
K750i W800 hung / freeze when memory card is inside Platijet Sony Ericsson Hardware Repair 138 03-01-2011 17:00
V3X Freezes when memory card is inserted S_mac Motorola Hardware Repair 2 08-06-2007 05:05
N73 freezes when memory card inserted mtb116 Nokia Base Band 5 ( BB-5 ) 2 07-31-2007 13:59
L7 freezes when memory card inserted chowdary Motorola Hardware Repair 2 07-22-2006 17:25
Page generated in 0.15299 seconds with 9 queries
