03-04-2008, 11:41 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Location: UK Age: 45
Member: 69358 Status: Offline Thanks Meter: 21 | E65 loudspeaker not working after TP unlock I badly need your help. Tried TP unlock on E65 and after reassembly loudspeaker stopped working. Already tried few time to reassemble with no luck. Initially no keypad sound was hearable, but somehow managed to get that working. Microphone is working, earpiece is working. But still no loudspeaker. Already searched through the forum with no luck. Thanks in advance. |
03-04-2008, 12:23 | #2 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 44
Member: 59489 Status: Offline Thanks Meter: 55 | Hiya Mate, Check your RAP closely under the microscope, there might be a chip on it. Had a similar one in, replaced everything, after closer inspection it turned out that the RAP had a chip, couldnt do anything about it, hope that helps. Best regards. |
03-04-2008, 12:50 | #3 (permalink) |
Member: 69358 Status: Offline Thanks Meter: 21 | THanks for quick reply. Do you mean the samsung chip with test points. I can see some chip on the left corner of the chip. Does this mean it is dead forever? Is it possible to replace the whole pcb/engine module? Best Regards |
e65 keypad not working after unlock | scoicagsm | Nokia Hardware & Hardware Repair | 3 | 08-09-2008 20:05 |
E65 loudspeaker/ringer not working after TP unlock | donish | J.A.F. Plus | 4 | 03-10-2008 20:34 |
A65 v7 keypad not working after tp | lezwire | E-Gold Based Phones | 6 | 01-15-2007 17:53 |
L6, 5 and 6 keypad not work after tp ??? | kimo59 | Smart-Clip | 8 | 05-11-2006 01:45 |
Modem not working after e616v unlock | pucuchu | NEC | 0 | 03-25-2005 06:40 |
