05-23-2009, 14:27 | #1 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Kuwait
Member: 735013 Status: Offline Thanks Meter: 74 | E66 display problem Flex cable & lcd is good because I already tried it into another same model phone.. Ive changed the 3 crystal ic for sure..I made it 6 times..but still the same.. Apparently,the board connector is in good intact, I already re soldered the terminal pins.. Status:The phone boot in normal condition,start-up tone, you can call the phone & able to switch-off. History: soaked in water. Thankz.. |
The Following User Says Thank You to czaren For This Useful Post: |
e66 display problem | mobifone | Nokia Hardware & Hardware Repair | 4 | 11-01-2010 15:26 |
Need e66 display solution | mobifone | Nokia Hardware & Hardware Repair | 7 | 09-22-2010 06:52 |
E66 display light problem | shahzad00786 | Nokia Hardware & Hardware Repair | 1 | 05-25-2010 14:14 |
5800 Display Problem (With Display On FBUS Cable But No Display using Regular Battery | eyestrain | Nokia Base Band 5 ( BB-5 ) | 1 | 06-21-2009 20:11 |
